14
Alert slider silent mode not working
  1. G_abhijeet_swain
    Eclair Apr 1, 2020
    #81
  2. drl431
    Nougat Apr 1, 2020
    drl431 , Apr 1, 2020 :
    Not reading the previous posts on this thread?
    #82
    buntycubal, Caomhin and Artemus. like this.
  3. Nisheethchau
    Cupcake Apr 7, 2020
    Nisheethchau , via OnePlus 6 , Apr 7, 2020 :
    how do you change it to silent mode?
    #83
  4. thesauravkarmakar , via OnePlus 6T , Apr 7, 2020 :
    When it happened first, I thought it was H/W issue and went to their Service Center (SC) and they fixed it in 5 minutes. They told me it's because of the dust.He recommend to clean it once in a week. So, if it doesn't work I visit the SC and get it cleaned. No other alternative.
    Why this happens?
    Design issue. Lot of gap is there so. This was the main issue in the 6 series.
    So, in there 7 Series they have changed the slider design.
    #84
  5. Artemus.
    Nougat Apr 7, 2020
    Artemus. , Apr 7, 2020 :
    It's called "maintenance". ;)
    #85
  6. deepakr83
    Cupcake Apr 29, 2020
    deepakr83 , Apr 29, 2020 :
    OMG.. this was the simplest way to fix this
    #86
    drl431, Artemus. and Caomhin like this.
  7. R1588277496280
    Cupcake Apr 30, 2020
    #87
    drl431 and Artemus. like this.
  8. I1588847995925
    Cupcake May 7, 2020
    I1588847995925 , May 7, 2020 :
    This started happening to me ever since I updated my phone to the latest Android version. It sucks.
    And there's no effing dirt in mine.
    #88
  9. drl431
    Nougat May 7, 2020
    drl431 , May 7, 2020 :
    Then you should contact OnePlus customer service to get your phone repaired.
    #89
  10. MarioNesturi
    Cupcake May 7, 2020
    MarioNesturi , May 7, 2020 :
    Had the same issue make sure to clean the canal of the slide button because it turned out that all the problem was that it was blocked , it looked like the button slided completely but it didn't
    #90
    Artemus. and drl431 like this.
  11. Q1560235119128
    Cupcake May 8, 2020
    Q1560235119128 , May 8, 2020 :
    Even mine had stopped working but I tried with slight force not in upwards direction but more of like a push and slide up direction and it worked. Definitely doesn't cover up for the issue but still works as temporary fix.
    #91
  12. Q1560235119128
    Cupcake May 8, 2020
    This actually helped!! Cleaning the canal properly is the key. Thanks!
    #92
    Artemus. and MarioNesturi like this.
  13. swebb99uk
    Donut May 9, 2020
    swebb99uk , May 9, 2020 :
    I had the same issue on my oneplus 5 it would randomly change settings even when not touching the phone. In the end and this sounds a bit iffy, I blew hard in to the switch and then sucked hard. Anyway it now appears to be fixed.
    #93
  14. Bowdown
    Cupcake May 19, 2020
    Bowdown , May 19, 2020 :
    I have same issue from today, unable to switch to silence mode, however loud and vibration mod working fine
    #94
  15. Artemus.
    Nougat May 19, 2020
    Artemus. , May 19, 2020 :
    Make sure you read the thread before blindly posting in it.
    #95
    buntycubal and Caomhin like this.
  16. saicharanpulikonda
    Cupcake Jun 10, 2020
    #96
  17. Yajat_Vishwakk
    Cupcake Jun 26, 2020
    Yajat_Vishwakk , Jun 26, 2020 :
    If you have your night mode on, it disables ring even on the alert slider. Turn off night mode and try again.
    #97
  18. Augustine Moses G
    Cupcake Jul 10, 2020
    #98
  19. Caomhin
    Marshmallow Jul 10, 2020
    #99
    buntycubal likes this.
  20. Augustine Moses G
    Cupcake Jul 11, 2020
    Caomhin likes this.
