14
Alert slider silent mode not working
  1. arun guna
    Cupcake Jul 25, 2020
  2. Ashish_Gupta18
    Froyo Jul 25, 2020
    Ashish_Gupta18 , via OnePlus 6 , Jul 25, 2020 :
    Guys! It's only a dirt problem. It happens as we have been using it from last 2 years. Go to OnePlus service center, they will clean it for free. Or you can google it how to clean it yourself.
    No need to make such big issue out of it.
  3. S1597225667299
    Cupcake Aug 12, 2020
    S1597225667299 , Aug 12, 2020 :
    Nothing to do with dirty. The slider is a flawed component of the phones. This is just pathetic. These issues exist from AT LEAST 2017 and are still present in 2020, and have not been addressed since. They even exist in the newer models. I planned on buying a new oneplus, but I will not. If they don't want to listen to the community, I will choose a better alternative. The phones became too expensive anyway. Greetings from a use to be fan of oneplus.
  4. Caomhin
    Marshmallow Aug 12, 2020
    Caomhin , via OnePlus 6T , Aug 12, 2020 :
    No flaw, dirt build up within a mechanical part. It happens, clean it out and you be grand. Many have done this to rectify the issue. Dust, lint etc will always build up in these things.
    buntycubal, Tee_Eee_Bee and drl431 like this.
  5. Jalteamyo
    Eclair Aug 12, 2020
    Jalteamyo , Aug 12, 2020 :
    I have the same issue on 6T McLaren edition
    when I apply some force while sliding it goes to silent mode
    strange
  6. S1597225667299
    Bullcrap. You probably are a oneplus troll. I cleaned the shit out of it, and the issue persists. Stop lying.
  7. S1597225667299
    Also, for work I use an IPhone with a slider. How come I never need to clean that slider, huh? This is a common error/flaw that causes a lot of frustration. It is mentioned in a lot of topics and oneplus never addresses it. Shameful!
  8. S1597225667299
    I checked your page. You indeed are a troll hired by oneplus, I guess to try to maintain a good image of the company by stating that dirt is the issue. Who else posts 9000 messages? You either are hired by oneplus or you have no normal life. The issue with the slider is present for years. Stop defending their crappy engineering and none existing policy of addressing issues.
  9. Caomhin
    Well then your one is physically broke then, does happen too. Go to an approved OnePlus service center and they can check it for you.
    buntycubal and drl431 like this.
  10. Caomhin
    No need to defend it, my 6T works in a spiffing manner. Absolutely no issue in over 20 months. Wonderful phone. Goes like a hot snot. Battery life is out of this world, 10 hours SOT easy.
    And my slider works the same as the day I bought it, perfectly.
    😎😎[e]1f44d[/e][e]1f44d[/e]
  11. S1597225667299
    Cupcake Aug 13, 2020
    S1597225667299 , Aug 13, 2020 :
    Don't listen to this fool named Coamhin. He is paid and part of the furniture of Oneplus. Of course he trolls in the benefit of Oneplus. These phones are kind of useless if they have this bug/defect. And no, warranty is already void.
  12. Caomhin
    Marshmallow Aug 13, 2020
    Caomhin , via OnePlus 6T , Aug 13, 2020 :
    As you can see from many of the posts further up, many people fixed theirs by Cleaning the Slider.
    If you still have issues with yours then Report the issue directly to OnePlus Developers as a Bug report.
    And also contact OnePlus support directly to see if they have more information on your issue. Scroll down the page for contact and online chat details.
  13. drl431 likes this.
  14. S1597225667299
    Cupcake Aug 14, 2020
    S1597225667299 , Aug 14, 2020 :
    No. I won't contact customer support. Because they don't do anything anyway about the issue (that's apparant).
    You can all say dust is the issue, but for many people it's not. And those many people will probably NOT buy an oneplus again, including me and my girl. I don't pay a lot of money for a phone that has those really dumb issues which could be easily addressed by software updates or new hardware adjustments for the newer models. But no. Oneplus goes the easy 'I don't care about you' route. Copied from your government, probably. They don't give a shit about you either.
  15. L1597541089103
    Cupcake Aug 16, 2020
    L1597541089103 , Aug 16, 2020 :
    I'm happy to till you that the smae problem happened to me and I managed to solve it by cleaning the sliding bar using a very fine needle.
    I used at the beginning the sim tray pin to remove the dust but the silent mode was still not working until I used the needle.
    The sliding bar is so sensitive😁
    drl431 likes this.
  16. drl431
    Nougat Aug 16, 2020
    drl431 , Aug 16, 2020 :
    Yeah, I do believe the tolerance for the alert slider is way too tight. As in, it only takes a small amount of dirt to limit the alert slider movement to cause problems.
    buntycubal and Caomhin like this.
  17. A1569249422720
    Cupcake Aug 24, 2020
  18. drl431
    Nougat Aug 24, 2020
    drl431 , Aug 24, 2020 :
    You could start by reading at least a few posts in this thread.
  19. ZeeshanNoor
    Cupcake Sep 20, 2020
    ZeeshanNoor , Sep 20, 2020 :
    I used to have the same problem it went only through vibration/ring but never mute even when I tried to use force, all I did was clean the slider by using a q tip or by using a toothpick and cleaning the interior of the slider. Worked for me hope it works for you.
    Caomhin and drl431 like this.
  20. T1600977242232
    Cupcake Sep 24, 2020
    T1600977242232 , Sep 24, 2020 :
    I am using a silicon case . If I use slider with it it gets bugs like you guys have but if I take the silicon case down then my button works fine. You should try it
