14
Alert slider silent mode not working
  1. T1600977242232
    Cupcake Sep 24, 2020
    T1600977242232 , Sep 24, 2020 :
    I am using a silicon case . If I use slider with it it gets bugs like you guys have but if I take the silicon case down then my button works fine. You should try it
  2. Artemus.
    Nougat Sep 27, 2020
    Artemus. , Sep 27, 2020 :
    Clear the slider.
  3. M1601874680422
    Cupcake Oct 5, 2020
    M1601874680422 , Oct 5, 2020 :
    The only solution that WORKED
    THANKS!
    (Amazing how many just ignored this post... Why would you clean anything if the switch is effortlessly going all the way up and clicking into position and you see no debris in there SMH... Clearly an internal hardware wear and tear issue... I've never liked having a mechanical switch for something like this, and this is part of the reason why... My estimation is even after this solution, at some point it'll just wear so much that it'll simply need replacing.)
  4. Caomhin
    Marshmallow Oct 5, 2020
    Caomhin , via OnePlus 6T , Oct 5, 2020 :
    Personally I find it a handy feature. For some cleaning the slider works, for others what you did works. And yes as it's a mechanical part I am sure it is prone to wear and tear if not used carefully.
    Mine still functions perfectly after nearly 2 years. Can't fault it.
    drl431 likes this.
