181
All about OxygenOS – Apr 2021
  1. Y1619816489392
    Cupcake Apr 30, 2021
  2. I1608321160629
  3. L1591959385497
    L1591959385497 , via OnePlus 7T , Apr 30, 2021 :
    Well, many of the oneplus users really wants back the exclusive font of the oneplus i.e the ONEPLUS SLATE. Please try to add the ONEPLUS SLATE ALONG WITH BOTH OF THE EXISTING ONES IN THE NEXT UPDATE. PLEASE! IT'S SO SOOTHING. 🙏
  4. D1570544572920
    iamrj likes this.
  5. O1593617425836
  6. V1575973616532
    V1575973616532 , via OnePlus 7T , Apr 30, 2021 :
    Too much heating..
    Screen rotate doesn't work..
    While playing game if u plug charger it rotates to vertical which cant be change without restarting ur phone.
    Charging is slow too
    iamrj likes this.
  7. UncleCupCake
    Gingerbread Apr 30, 2021
    UncleCupCake , via OnePlus 8T T-Mobile , Apr 30, 2021 :
    Do a clean reset and install of the os do not use back ups.
  8. nawazshafiq1
  9. G1539362505368
    G1539362505368 , via OnePlus 7T , Apr 30, 2021 :
    After the system got updated to Oxygen OS 11, there is lot of lag in the system and also there is also wifi connectivity issue. Suddenly wifi gets disconnected and suddenly it gets connected. Battery is draining a lot even after switching off few features that might consume a lot of battery.
    It will be very helpful if you guys can fix these issues.
  10. N1569654344472
    iamrj and md_shadan like this.
  11. Nadeem2
    Cupcake May 1, 2021
    Nadeem2 , via OnePlus 7 , May 1, 2021 :
    After updating my OP7 to OS11 fast charge is not working. Facing this issue from last 3 days.
    Wifi switching is very slow it doesn't disconnect weak wifi signal even if there is another wifi available. I have to turn off and on connect ok.
  12. Shehbaztian
    Froyo May 1, 2021
  13. SHIKHA826
    Cupcake May 1, 2021
    SHIKHA826 , via OnePlus 7 , May 1, 2021 :
    The wifi keeps on disconnecting after evry 1-2 mins. After connecting, first it will show as no internet. Then after 10 secs,bir will connect automatically. This is very frustrating because it keeps on repeating every 1/2 mins.
    The issue can only be seen in phone qhere 2 wifi are connected. 1 for 5Ghz and another for 2.4Ghz
    Please update this issue as well in next update. It's become very hectic to use the phone.
    Harshi_2118 likes this.
  14. rahil_k_akber
    Froyo May 1, 2021
  15. ahmedbajaber95
    Cupcake May 1, 2021
  16. P1617650057176
    Cupcake May 1, 2021
    P1617650057176 , via OnePlus Nord , May 1, 2021 :
    Call answering time phone is not responding and white screen is showing even contact number also not visible in OnePlus nord phone please do needful help in 12GB model
  17. YUshaRani
    Froyo May 1, 2021
  18. Kshitij_Bodhankar
    Cupcake May 1, 2021
    Kshitij_Bodhankar , via OnePlus 7T , May 1, 2021 :
    Not really happy with the update in one plus 7T. Updated display is bad. Would give anything to go back to the previous version for display. Faster battery drain. Slower dash charging. Camera updates are good though.
    Harshi_2118 and md_shadan like this.
