177
All about OxygenOS – Apr 2021
  1. H1620552351632
    Cupcake May 9, 2021
    H1620552351632 , via OnePlus 7 Pro , May 9, 2021 :
    Hey I've got a OnePlus 7 pro and did the new oxygen update 11.0.0.2.GM21BA and for some reason my front camera is not working I've not dropped it or anything there is no visible damage on the camera. It only happened after the update. Can some please help me or tell me how much it is to get fixed ?
    Please help...
  2. MYZBK
    Cupcake May 9, 2021
    MYZBK , via OnePlus 7 Pro , May 9, 2021 :
    The most annoying thing so far since the update is that there is no longer an option to hide the navigation bar, I don't want to use the gestures, please bring back the hidden navigation bar.
  3. johndavidjojo
    Cupcake May 9, 2021
  4. I1589714429435
    Donut May 9, 2021
  5. PranavTeji99
    Cupcake May 9, 2021
    PranavTeji99 , via OnePlus 7T , May 9, 2021 :
    I am using OnePlus 7t. I have heard some rumours of Oxygen OS latest update that it is not good or have many many bugs. Suggest me, if it Is resolved so that I can update my device.😇
  6. Biswajit Padhi
    Froyo May 9, 2021
  7. alloyce22
    Cupcake May 9, 2021
  8. Z1511278517115
    Cupcake May 9, 2021
    Z1511278517115 , via OnePlus 7 Pro , May 9, 2021 :
    I am unable to connect to internet through my data usage on OnePlus 7 Pro after Oxygen 11 update. I can get internet through WiFi, but not data usage. Also, text messages are not downloading even when I have WiFi. All this started with last update.
    Anyone have a fix for this? I have done everything I have found so far and no change. I am ready to fix this by changing the phone and not to OnePllus.
  9. G1524004097529
    Cupcake May 9, 2021
  10. k7ashif
    Eclair May 9, 2021
  11. ChipsTR , via OnePlus 7T Glacier Blue , May 9, 2021 :
    A phone company that has not been able to beta test the AOD feature for 1 year is a mediocre company for me. I regret that I chose this brand, they are incapable of fixing their problematic software. I think incompetent employees and managers should be fired.
  12. Jonah4384
    Cupcake May 9, 2021
    Jonah4384 , May 9, 2021 :
    Why on earth you need os11 bro when you are already having a master piece(os10). Manu users reported issues with the recent os11 update. I'm a op7pro user and I have received os11 update a couple of weeks ago and I'm simply ignoring it. Oxygen Os is suuuper cool bruhh!![e]1f609[/e]
    Dark_Flash likes this.
  13. Jonah4384
    Cupcake May 9, 2021
    Yes, indeed. Os 11update has lots of bugs and issues to fix. My suggestion is to stick to your super cool Oxygen OS10 with the amazing skin and interface. Peace!
  14. M1571923633455
    Cupcake May 9, 2021
    M1571923633455 , via OnePlus 7T , May 9, 2021 :
    Even I am also facing the same issue on my 7 t, free installalling oxygen 0S11.Charging issue,Auto update issue,Auto rotating issue.Its really worst
  15. iabhishekd
    Cupcake May 9, 2021
    iabhishekd , via OnePlus Nord , May 9, 2021 :
    Touch to unlock does not work most of the times on Nord, apps close automatically, sometime app on the screen doesn't allow to pull home screen or move to other app... please fix it ASAP it's very annoying
  16. Dark_Flash
    Eclair May 9, 2021
    Dark_Flash , via OnePlus 7 , May 9, 2021 :
    Even having single wifi channel isnt doing any good. Wifi connection randomly drops. Disconnects and connects again.
    Divyajeevan likes this.
  17. V1620565547042 , via OnePlus 7T Pro 5G , May 9, 2021 :
    Im sure tons of negative remarks have already been made about problems with Bluetooth, but after the android 11 update was done last night I went to get into my car and thought the constant disconnecting would probably be done with, now when the phones connected to bt and I plug the charger in the Bluetooth shuts off and doesn't reconnect until I manually go in to reconnect... This is really becoming an annoying problem, I'm getting rid of this phone
  18. Dark_Flash
    Eclair May 9, 2021
    I dont use bluetooth often. God knows how many more bugs planted in the last update. Annoying!
