139
All about OxygenOS – August 2021
  1. F1632250435605
    Cupcake Sep 21, 2021
    F1632250435605 , via OnePlus 6T , Sep 21, 2021 :
    Thank you for your responses.
    But I mean that's basic, right? You don't find a solution, do a backup and factory reset. You don't know what's happening to your phone/laptop, you restart. I am just trying to find a solution first before getting there.
    rhyd1am likes this.
  2. rhyd1am
    KitKat Community Expert Sep 21, 2021
    rhyd1am , Sep 21, 2021 :
    Yes that's fine. Although the solution to your original query had already been given. Your question was asking if there was a way to uninstall the update.
    The answer to that question is yes, but that would involve wiping the device (as is always the case when rolling back). The other option would be (as suggested above) a factory reset after backing up. That would be my first choice in your position since you seem to have a number of issues.
    I was in no way trying to make light of your situation, I was merely surprised that you did not appear to have an existing backup of your important things. 🙂
    Dresa91 and Artemus like this.
  3. F1632250435605
    Oh yes. Apologies if it sounded rude. I am super annoyed with my phone rn. So, rudeness was for the phone, not for you. You are just helping. So, thank you.
    For the backup, I haven't taken any for the past one year and now I can't see anything. I am hoping it would show once I connect it to the laptop🤞
    rhyd1am likes this.
  4. rhyd1am
    No problem at all, hopefully backing up using your PC and a reset will resolve your issues 🙂
    Dresa91 and F1632250435605 like this.
  5. A1629509521032
    Cupcake Sep 23, 2021
  6. A1629509521032
  7. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Sep 23, 2021
    Caomhin and Dresa91 like this.
  8. Peralt4
  9. Jitesh8992
    Eclair Sep 24, 2021
    Jitesh8992 , via OnePlus Nord 2 , Sep 24, 2021 :
    My OnePlus Nord 2 is getting hanged & running very much slow without any reason. Even after having 12 GB of RAM.
    I have tried to uninstall heavy games also & doing multiple restarts, but still issue has not been resolved.
    Kindly help me to fix this issue at the earliest.
  10. isachinpal
    Gingerbread Sep 24, 2021
    isachinpal , via OnePlus Community App , Sep 24, 2021 :
    Enable ram boost
  11. Jitesh8992
    Eclair Sep 24, 2021
  12. isachinpal
  13. Jitesh8992
    Eclair Sep 24, 2021
    I agree, as till yesterday evening every thing was working smoothly. But then from night onward it has become very slow.
    I was also playing Call of Duty at the max settings & it was working much smoothly.
    But now while scrolling through the apps also it is lagging, even settings page is also scrolling very slowly.
  14. isachinpal
    Bro go in backup and reset > reset system settings only .
    Hope it will work for you
  15. Jitesh8992
    Eclair Sep 24, 2021
    Thanks, will have to check it at last, if issue is not resolved.
    Because as of now it is working after completely discharging the battery I again charged it to full & now my mobile is working fine, as of now.
    I will check today if again facing any issues, then I need to reset the system settings at last.
  16. isachinpal
    Yes but reset only system settings not factory reset
  17. Jitesh8992
    Eclair Sep 24, 2021
  18. macmynx
    Cupcake Sep 24, 2021
    macmynx , via OnePlus 6T , Sep 24, 2021 :
    Dears maybe some one have this same, in my 6T the light sensor is crazy. The pocket function is not working, the automaticly screen light is not working. It's generate a lot of small but irritating problems. Maybe some one has solution for that? everything start happening after August update
    Thx in advance.
  19. malidan
    Nougat Sep 24, 2021
    malidan , Sep 24, 2021 :
    He got 12 of ram.
