Always on display issue via OnePlus 9 Pro
  1. [email protected] , via OnePlus 9 Pro , Oct 28, 2021 :
    My oneplus 9pro always on display is not going to sleep(sleep time is set to 30 sec). It is draining a lot of battery I am on the latest software build and update anyone also facing similar issue and if possible any fix thanks.
  2. Shailender Sharma
    Nougat Oct 28, 2021
    Best Answer
    Shailender Sharma , Oct 28, 2021 :
    There is no fix, you have to select the correct Settings yourself.
    Go to Settings - Display - Ambient display - (when to show) Always-on ambient display - Select off
    Caomhin, the_o2, drl431 and 1 other person like this.
  3. [email protected] , via OnePlus 9 Pro , Oct 28, 2021 :
    Thax for the advice it helped .
    the_o2 and Shailender Sharma like this.
  4. Shailender Sharma
    Nougat Oct 28, 2021
    Caomhin and the_o2 like this.
