2
Am I mad thinking of buying op2 instead of op3
  1. Moin2200 KitKat Jun 15, 2016
    #41
  2. Amjass12 Honeycomb Jun 15, 2016
    Amjass12, Jun 15, 2016 :
    Yes
    #42
    Lorde Voldmort likes this.
  3. zeus.01.01.01.01 Lollipop Jun 15, 2016
    zeus.01.01.01.01, Jun 15, 2016 :
    i'm thinking of getting the OP2 instead of OP3 too .... OP3 is a bit expensive for me ... i was waiting so that i could get th e 4 GB ram variant of it .. but in the latest AMA oneplus clarified that there won't be a 4 GB ram version ... and here i am with no choice but to get a oneplus 2 or something like the leeco lemax 2
    #43
  4. Jitesh Saitawadekar KitKat Jun 15, 2016
    Jitesh Saitawadekar, Jun 15, 2016 :
    Yeah same here next upgrade will be after a year will use OPT for one more year, if OP4 tempts me then i'll go for it or else wait for Nexus series.
    #44
    locxFIN likes this.
  5. Markus214 Honeycomb Jun 15, 2016
    Markus214, Jun 15, 2016 :
    I bought a OP2 instead of OP3 so I'll be the first to be ridiculed about not buying the OP3 .Sorry to me it's just not something that attracts me right now. Its all about your personal preference .
    I bought OP2 really good price under $200 USD
    #45
  6. locxFIN KitKat Jun 15, 2016
    locxFIN, Jun 15, 2016 :
    Same here. 2017 is what I'm looking forward to regarding smartphones. If OP4 too has unlocking covered warranty, it's quite hard to pass up but, on the other hand, if 2017 Nexus (or any other phone for that matter) is just awesome in both hardware and software section and comes at around the same price I might not need to tinker with the device.
    #46
  7. johnblock Gingerbread Jun 15, 2016
    johnblock, Jun 15, 2016 :
    For people who budget for an expensive phone each year, getting a new one after 6 months works out the same.
    #47
  8. TiramisuNY Jelly Bean Jun 15, 2016
    TiramisuNY, Jun 15, 2016 :
    OP3 specs make it that much better. If I hadn't just bought the OPX as a quick fix to my drowned OP2, I would get the OP3 at the Pop-Up event today. I'll still go to try out the OP3.
    #48
  9. johnblock Gingerbread Jun 15, 2016
    Congratulations on your new Opt.
    Compared to some other phones, you would still be ahead if you changed your mind and got both.
    #49
  10. malidan Marshmallow Jun 15, 2016
    malidan, Jun 15, 2016 :
    Fair enough, you could also try the Letv pro 1 on sale at £120-140 with an 810 clocked at 2.5. Crazy money for the specs
    #50
  11. malidan Marshmallow Jun 15, 2016
    #50
    #51
  12. aneesimran Honeycomb Jun 15, 2016
    #52
    TiramisuNY likes this.
  13. d1beats Jelly Bean Jun 15, 2016
    #53
  14. Lorde Voldmort Gingerbread Jun 16, 2016
    Lorde Voldmort, Jun 16, 2016 :
    Alright, thanks! 'Cause I wanted to buy it but since the price is too high (for me) I am reconsidering to wait!
    #54
  15. nobelium76 KitKat Jun 16, 2016
    nobelium76, Jun 16, 2016 :
    If you want a OnePlus product but you're not sure you want to shell out for the OP3, I'd go with the OPO. Its a solid phone that has a good OS and will be relevant CPU wise for a while. Too bad COS support is just about over, but it would be worth it to me.
    I am currently still using the OPO I bought in August 2014. I might get the OP4...
    #55
  16. F_Vikram_Cm_xyPn Cupcake Jun 16, 2016
    #56
  17. josefn24 Jelly Bean Jun 16, 2016
    josefn24, Jun 16, 2016 :
    Op3 if it's 100$ difference especially better screen processor camera more ram and quick charge. People said the same thing last year between the opo and op2 and I have both definitely worth the upgrade at 100$ difference.. why would you want last year's phone anyway for that price when you could probably find one gentle used for half the price. That's my opinion anyway enjoy your new phone whichever one you choose..
    #57
  18. josefn24 Jelly Bean Jun 16, 2016
    You can use it but obviously it won't charge your op2 any faster and you can't use old cables with it
    #58
  19. TiramisuNY Jelly Bean Jun 17, 2016
    TiramisuNY, Jun 17, 2016 :
    Loved my OP2 but after handling the OP3 yesterday, I'd definitely spend a bit more to get the OP3 for the Dash Charge, Smile Capture and 6 GB RAM.
    #59
    andreamoro likes this.
  20. andreamoro Donut Jun 19, 2016
    andreamoro, Jun 19, 2016 :
    Not a big deal the grey option. First grey telephone, and it's just on the back. Well in my case even the rest as I got their grey flip cover too, but it's elegant enough, so save those 20 bucks.
    #60
