Amazing Battery Life!
  1. Joe Stallmeyer
    Donut Aug 2, 2014
    Joe Stallmeyer , Aug 2, 2014 :
    I have to say this is incredible. This was my first charge after I got it, I had 40% then I opened it which I let drain to 28% then charged it up to 96%. Whats weird is that it got up to 96% then would not go any higher, so I rebooted and it changed to 95% and wouldn't go up. (This is after the photos were taken) So then I let it die completely and charged to full. Very quickly after turning it on the battery % went to 95%, strange...
    I had the brightness on about 20% which in my opinion is perfect because the display is very bright even at low levels. But 6:30 hours of screen on time, I couldn't believe it until I saw it myself!
    [​IMG] +[​IMG]
  2. BobbyStevie
    Honeycomb Aug 2, 2014
  3. Hanson Lee
    Marshmallow Aug 2, 2014
    Hanson Lee , Aug 2, 2014 :
    It's really so amazing that even if I want to drain it to zero percent it is as difficult as attracting a girl to you.
  4. fabiotasa2
    Gingerbread Aug 2, 2014
  5. michaelg626
    Froyo Aug 2, 2014
    michaelg626 , Aug 2, 2014 :
    If you want to hit 100%, once you notice it isn't going any further unplug and plug it back it. It will go up another percent or two. Just keep doing that and you will hit 100%.
    Its a design so the battery isn't being overcharged.
  6. Joe Stallmeyer
    Donut Aug 2, 2014
    Wow if your going to try to insult me make it sound good, that wording was atrocious. I feel embarased for you...
  7. Hanson Lee
    I never wanted to insult you. Just that really it's hard to drain it to zero.
  8. Joe Stallmeyer
    Donut Aug 2, 2014
    Never thought about that, thanks for the comment!
  9. Joe Stallmeyer
    Donut Aug 2, 2014
  10. jdh10475
    jdh10475 , Aug 2, 2014 :
    That is hard on a lipo battery... 2%.
    Lithium polymer batteries live best at 30-90%. Over or under charging them greatly decreases the life of the battery. Just a heads up.
  11. Joe Stallmeyer
    Donut Aug 2, 2014
    I know you were joking ;), Im just a smart ***:)
  12. HugoDerHeld
  13. Joe Stallmeyer
    Donut Aug 2, 2014
  14. bakal_daw
    bakal_daw , Aug 2, 2014 :
    We'll it's a new phone so it should have a good battery life. Also, could be due to CM stock android and less bloat. Just like my driver running custom rom 4.4.4 which breezes easily past 16 hours a day in a single charge...;)
