Ambient display brightness settings?
  1. trandaa
    Froyo Aug 1, 2017
    trandaa , Aug 1, 2017 :
    Hello, I would like to ask, if there is some way to change the brightness of the ambient display on OP5. Because in my case it seems maxed out. In the night it's quite disturbing when you want to check notifs.
    Thanks
    Trandaa
  2. Nepariri
    Gingerbread Aug 1, 2017
    Nepariri , Aug 1, 2017 :
    Thats why theres nightmode and reading mode
  3. trandaa
    Froyo Aug 1, 2017
    Night mode partially dim the display and limits the blue colour. But with maxed brightness it's still uncomfortable.
    Reading mode just makes the display BW. And ambient display is already BW only, so that won't help much.
  4. VaibhavBhargava
    Lollipop Aug 2, 2017
    VaibhavBhargava , Aug 2, 2017 :
    Why don't you turn on the adaptive brightness ?
  5. biplabloveu
    Ice Cream Sandwich Aug 2, 2017
    biplabloveu , Aug 2, 2017 :
    mine is working as per the current screen brightness as it should be. better you try by using formatting the phone or contact support.
  6. juicebones99
    Cupcake Jul 22, 2018
    juicebones99 , Jul 22, 2018 :
    I agree. The ambient mode is way too bright. It's hardly ambient.
    As for using auto brightness . . . no, it's broken. Useless. As with every phone I've ever used. Display is too dark in a dark room when I an using the phone.
    Night mode and reading mode only adjust the chroma, not the luminosity of ambient. Still too bright.
    Maybe nitpicking. But I don't use the feature anymore.
  7. MentalDraco
    Marshmallow Jul 23, 2018
    MentalDraco , Jul 23, 2018 :
    That's quite the revival you have done here
  8. vladYanutanOnePl
    Cupcake Nov 21, 2018
    nima_arya likes this.
  9. nima_arya
    Cupcake Aug 14, 2019
    nima_arya , Aug 14, 2019 :
    Let me know if you find any solution please...
  10. Waveform Modifier
    Marshmallow Aug 14, 2019
  11. nima_arya
    Cupcake Aug 20, 2019
  12. Waveform Modifier
    Marshmallow Aug 20, 2019
    Waveform Modifier , Aug 20, 2019 :
    Not a OnePlus issue. Complaint to Google instead.
