3
Ambient display issue via OnePlus 7
  1. LAST_KINGS
    Donut Jun 3, 2020
    LAST_KINGS , via OnePlus 7 , Jun 3, 2020 :
    After the update of 10.3.3.GM57AA the ambient display is not working. Tap the screen to show is not working as expected and the way it was working before the update. How to fix this.??
    GenesisB, Shivam_Kotak and m3rs3d like this.
  2. Shivam_Kotak
    Donut Jun 3, 2020
    Shivam_Kotak , Jun 3, 2020 :
    same for me. I don't recieve notifications in ambient display and also tap to wake feature is not working most of the times.
    F1589782428489 likes this.
  3. Artemus.
    Nougat Jun 3, 2020
    Artemus. , Jun 3, 2020 :
    Do you have the option selected in Ambient Display or do you have "double-tap to wake" enabled?
  4. Shivam_Kotak
    Donut Jun 3, 2020
  5. Artemus.
    Nougat Jun 3, 2020
    Okay, so this is a completely different feature. You can't have both turned on, it'll turn off the opposite option automatically.
    Shivam_Kotak likes this.
  6. Shivam_Kotak
    Donut Jun 3, 2020
    I know that. I only use tap the screen to wake and it worked each and every time before the update but now it's a hit or miss kind of thing.
    LAST_KINGS likes this.
  7. Artemus.
    Nougat Jun 3, 2020
    Works perfectly for me.
  8. LAST_KINGS
    Donut Jun 4, 2020
    LAST_KINGS , via OnePlus 7 , Jun 4, 2020 :
    Same, even I use only the tap the screen option. But somehow after the update it is not working.
  9. Shivam_Kotak
    Donut Jun 4, 2020
    Shivam_Kotak , Jun 4, 2020 :
    I see lots of similar posts. Hope they fix it quickly.
    HijodeRex likes this.
  10. donPepitoGrillo
    Honeycomb Jun 4, 2020
  11. Hemanth.E
    Cupcake Jun 4, 2020
  12. anurag.k.a
    Cupcake Jun 4, 2020
  13. prasad321
    Gingerbread Jun 5, 2020
    prasad321 , via OnePlus 7 , Jun 5, 2020 :
    i am facing the same problem. let me explain how to reproduce.
    i am on stable build 10.3.3 on my OnePlus 7
    1. enable tap to wake in ambient display or double tap to wake up the screen in setting->button and gestures.(both can not be enabled at same time as of now)
    2. it will work if you instantly check after enabling it. but if you lock the screen and place the phone untouched for more than 15 min and then try to tap or double tap it will not work.
    my thought is, its killing the background process of double tap or single tap while increasing the battery backup.
    I have raised the bug for the same lets see when it will get resolved.
    Thanks,
    Prasad
  14. LAST_KINGS
    Donut Jun 5, 2020
    LAST_KINGS , via OnePlus 7 , Jun 5, 2020 :
    Yes, even I believe this is how the battery life has been increased. But it's limiting the user experience.
  15. prasad321
    ofcourse. this feature is important like calling feature in phones.
