Display Ambient Display (lift to display) Not Working
  1. poe_fosho
    Froyo Feb 10, 2020
    poe_fosho , Feb 10, 2020 :
    Hello,
    Currently on the 10.3.1 (newest image) and previous android 10 release, both will not allow the lift to turn on display to work. To turn on the display I must push the power button.
    I have checked in the settings and the option is enabled, but it will not work. Nothing seems to be blocking the sensors in the front of the phone.
    Has anyone else experience this?
    thanks for any help.
  2. DrJMun
    KitKat Feb 10, 2020
    DrJMun , Feb 10, 2020 :
    Did you reformat? If you did then you should submit a bug report via Feedback.
    poe_fosho likes this.
  3. poe_fosho
    Froyo Feb 11, 2020
    poe_fosho , Feb 11, 2020 :
  4. poe_fosho
    Froyo Feb 11, 2020
  5. vl.str
    Froyo Feb 16, 2020
    vl.str , Feb 16, 2020 :
    Doesn't work here either but I suspect some conflict with ambient screen while charging from google... still looking for a solution
