Ambient display not working via OnePlus 7T
  1. B1592926700385
    Cupcake Jul 29, 2021
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Jul 29, 2021
    Dresa91 , Jul 29, 2021 :
    Did you enable it in settings?
    Can you please clear cache in recovery and try again?
    Does!Compute likes this.
  3. B1592926700385
  4. B1592926700385
  5. Dresa91
    What OxygenOS Version are you using?
  6. B1592926700385
  7. Dresa91
  8. B1592926700385
  9. Dresa91
  10. B1592926700385
    B1592926700385 , via OnePlus 7T , Jul 29, 2021 :
    Actually it isn't working earlier so I checked for updates too. There was an update so I installed it but the problem is still there
  11. Dresa91
    Can you please check it in safe mode?
    If you still facing this issue, you have some options:
    1. Submit a bug report via https://forums.oneplus.com/feedback and wait for the next update
    2. Reset your phone
  12. B1592926700385
  13. Dresa91
    You are welcome:)
  14. Does!Compute
    KitKat Jul 29, 2021
    Does!Compute , Jul 29, 2021 :
    Do you have Double Tap to Wake set On? If yes, try disabling it and then check if the issue gets resolved.
    Dresa91 likes this.
  15. B1592926700385
