Ambient display problem via OnePlus 7T
  1. TumulNigam
    Froyo Apr 24, 2021
    TumulNigam , via OnePlus 7T , Apr 24, 2021 :
    I just updated my OnePlus 7t with the latest Android 11 update, it was working fine on day 1 but now the ambient display and the horizontal line aren't working!!
    Plus there are wifi disconnecting issues: my 5ghz wifi disconnects even from a low range
    All of this is happening since the 2nd day after the latest update!!
  2. U1577186131630
    Cupcake Apr 25, 2021
  3. TumulNigam
    Froyo Apr 26, 2021
    TumulNigam , via OnePlus 7T , Apr 26, 2021 :
    It worked after I cleared cache from system app named ambient display and restarted my phone few times after that
  4. TumulNigam
    Froyo Apr 26, 2021
    Wifi is still a problem I'm facing
  5. juttuka.pavan
    Ice Cream Sandwich Apr 30, 2021
    juttuka.pavan , via OnePlus 7T , Apr 30, 2021 :
    Ambient display not work until you move your mobile or you put charging.because, always on display feature under development for 7 series.so, ambient display can't display always.i think next update ,your problem will solve.
  6. TumulNigam
    Froyo May 6, 2021
    TumulNigam , via OnePlus 7T , May 6, 2021 :
    U misread what I wrote
  7. TheMystic
    Lollipop May 6, 2021
    TheMystic , May 6, 2021 :
    Settings/ WiFi & Network/ WiFi/ WiFi Preferences/ Intelligently select the best WiFi.
    Disable it. Reboot, if necessary.
    If that doesn't help, and your router lists 2.4GHz and 5GHz bands with separate SSIDs, then ‘forget’ the 5GHz connection.
  8. TumulNigam
    Froyo May 6, 2021
    I'll try but from a few days wifi is disconnecting from my device every 10-20min
  9. KaustubhNaik95
    Gingerbread May 6, 2021
  10. juttuka.pavan
    Ice Cream Sandwich May 7, 2021
    juttuka.pavan , via OnePlus 7T , May 7, 2021 :
    Until, always on display feature not there . These problems commenly occurs.i am also facing same issues horizontal line and ambient display.
  11. TumulNigam
    Froyo May 7, 2021
    TumulNigam , via OnePlus 7T , May 7, 2021 :
  12. corpierro
    Donut May 7, 2021
    corpierro , via OnePlus 7T , May 7, 2021 :
    I also have Ambient display problems after update to version 11, double tap to wake/show and raise phone to wake do not work under low light conditions. If you cover selfie lens it's also blocked. It seems that face recognition becomes active and blocks further functioning. I discovered some improvement by going to face recognition feature in settings an be shure everything is deactivated en close setting afterwards.
  13. corpierro
    Donut May 7, 2021
    I have not seen horizon line function working at all. In settings I cannot deactivate it only can change color. But wat is the function if you don't have a curved (waterfall) edge screen? No side menus either. Maybe a lot of 7 and 7T problems because the software is intended for 7 Pro or 7T Pro? Do I miss this is the 7/7T group?!
