[Submitted] Ambient light sensor
  1. E1624210326227
    Cupcake Jul 29, 2021
    E1624210326227 , Jul 29, 2021 :
    There is an issue with automatic screen display
    , Ambient light sensor.
    The screen dims automatically in bright sunlight and well light room and gets bright under darkness.
    Even after keeping it in manual and setting it manually it changes brightness according to its mood.
  2. Suhas Klkrn555
    OnePlus Bug Hunter Staff Member Jul 29, 2021
    Suhas Klkrn555 , Jul 29, 2021 :
    We'll definitely work on the issue reported and we'll do our best to help you. We've got in touch with you via direct message. Looking forward for your response!
    Thanks & Regards,
    Suhas.
