AMOLED blacks looks grey on lock screen
  1. wkewinw
    Gingerbread Nov 4, 2018
    wkewinw , Nov 4, 2018 :
    I have this picture as my lock screen wallpaper. the blacks appear grey on my lock screen. if this normal? but blacks on home screen looks fine. when I turn on the screen the black kinda shifts from black to grey.
  2. Photoman9988
    KitKat Nov 4, 2018
    bharadwaj9r, Dante1 and Bouncer71 like this.
  3. wkewinw
    no... xD I posted the picture as a reference (I think that's the right word) black is black in the picture but grey on my lock screen
  4. skywalkr08
    Donut Nov 4, 2018
    skywalkr08 , Nov 4, 2018 :
    I think there's always been a small tint on the lockscreen, from the accent colour? Although correct me if I'm wrong
    wkewinw likes this.
  5. wkewinw
    yeah I mean I just got paranoid that something was wrong, before this wallpaper i had a picture with more colors so I didn't really think of the colors being a bit washed out. but now with a black one it really made a difference. my accent color is magenta so it can't be that. perhaps everything is as it should be. but if the greyish tint was removed my lock screen would look much better
  6. skywalkr08
    Donut Nov 4, 2018
    wkewinw
    yeah I mean I just got paranoid that something was wrong, before this wallpaper i had a picture with more colors so I didn't really think of the colors being a bit washed out. but now with a black one it really made a difference. my accent color is magenta so it can't be that. perhaps everything is as it should be. but if the greyish tint was removed my lock screen would look much better​
    Do one thing. If you have any notifications at lockscreen, try swiping up to pin/password entering screen. It should be clear then, with no tint
    Edit: My bad. Swipe down to expand a notification. The tint reduces then
  7. wkewinw
    I tried that before as well. while on the pin screen it is even brighter
  8. wkewinw
    it is still the same as directly on the lock screen I'm on pie 9.0 btw
  9. skywalkr08
    Donut Nov 4, 2018
    wkewinw
    it is still the same as directly on the lock screen I'm on pie 9.0 btw​
    Idk, I've always noticed the tint. I like to think it's from the accent colour for slightly blurring out background for better notification visibility
    And yeah, I'm on OOS 9.0.2 myself
    wkewinw likes this.
  10. Photoman9988
    KitKat Nov 4, 2018
    Photoman9988 , Nov 4, 2018 :
    Oh, gotcha. Yes, it's just the lock screen. There's a slight grey tint my design, nothing to worry about.
    wkewinw likes this.
  11. wkewinw
    hmm yeah it's possible, well thank you for your input [e]1f601[/e]
    skywalkr08 likes this.
  12. wkewinw
    alright [e]1f601[/e]
  13. wkewinw
    I just realized something. it's probably good that there is a grey tint. the lock screen clock would not be fully visible if let's say in my case the white flower is a bit under the numbers that's probably why there is a tint.
  14. Iulian R.
  15. wkewinw
    yeah it's always visible. you can try for your self. set a pitch black wallpaper on lock screen and home screen. you should see a difference.
  16. Iulian R.
    Iulian R. , Nov 4, 2018 :
    let me try
    wkewinw likes this.
  17. Iulian R.
    for me the blacks are still pure blacks. perhaps it has to do with the wallpaper app you're using?
    wkewinw likes this.
  18. wkewinw
    I downloaded the picture in my first post from wallhaven. I'm using OnePlus launcher. maybe it is while setting the lock screen wallpaper with the OnePlus launcher that makes it tinted
  19. Iulian R.
    also, is it tinted to a specific color?
  20. wkewinw
    no it just makes the whole picture color lighter. in night mode it is a more red color since night mode makes the screen more red.
    without night mode it's like the exposure is turned up a bit.
