101
An update about Open Beta 12 for OnePlus 7 Pro and 7
  1. cruzAD
    Gingerbread May 5, 2020
    cruzAD , May 5, 2020 :
    Yes, I installed OB12 on unencrypted phone and cache was also wiped before the update. I use pattern and fingerprint, what I turned on again, after the update and there is no problem to unlock my phone. (I has some fingerprint issue with a 3th party app, what was not present before the update).
    One annoying issue is the heating, during charging, and during screen on usage. It would became very hot if I use the phone continously while screen is on. I don't experienced it before. I was always wondering when people complained about heating issues, because I never experienced them, but now with OB12 it's heats a lot.
    I'm started to consider to switch back to stable or previous beta, because the heating is really hard. Fortunately I have a 6T also, so I can avoid to use the 7 with screen on for longer times, so I can wait for the update, but it is uncomfortable
    gianluigino likes this.
  2. androjas
    Donut May 5, 2020
    androjas , via OnePlus 7 Pro , May 5, 2020 :
    que raro, tengo la beta 12 instalada en mi op7 pro, y no e tenido problemas, ni de desbloqueo ni nada, el problema está en el desbloqueo facial?
    (solo tengo la duda si los que tenemos instalada la beta 12 recibiremos la actualización de la próxima beta 12)
  3. gianluigino
    Donut May 5, 2020
    gianluigino , May 5, 2020 :
    thanks a lot. I think the heat is due from the season, here is pretty hot compared to 2 month ago, or even less. I'm still on ob11 and in last week my phone is already get hot few time. anyway actually I have only this phone, so I think i'll wait next update. thank you again
    cruzAD likes this.
  4. Naytun
    Donut May 5, 2020
  5. Jav P
    Honeycomb May 5, 2020
    Jav P , via OnePlus 7 , May 5, 2020 :
    Los problemas más serios solo han afectado a un pequeño porcentaje de teléfonos, lo suficiente para parar la actualización. No te preocupes, cuando llegue la 13 vas a recibir la notificación y vas a poder actualizar normalmente.
  6. AubreyPrice316
    AubreyPrice316 , via OnePlus 7 Pro , May 5, 2020 :
    Why don't you just stop the Beta updates and stick with Stable. No apologies required then. Yes but you gotta ensure the stable updates are being received once every month without fail
  7. androjas likes this.
  8. O1561987990774
    Cupcake May 5, 2020
    O1561987990774 , May 5, 2020 :
    Tengo instalada la beta 12 y el único problema que tengo es que en periodos largos de inactividad tengo que presionar el botón de power para que se reactive la pantalla. La duración de batería es excelente ni quisiera actualizar a la siguiente versión, no la vayan a estropear.
  9. O1561987990774
    Cupcake May 5, 2020
    Cuando lo dejo bastante tiempo en stand by, doy ya sea un toque o doble en la pantalla para que se active y no funciona, tengo que presionar power una vez para que se active y vuelva a funcionar tocando la pantalla. Intentaré borrando el caché en Recovery
  10. Fererio
  11. vriesdejoop
    Ice Cream Sandwich May 5, 2020
  12. Fererio
  13. Jav P
    It will have a different name and build number.
  14. Swejuggalo
    Community Bug Hunter May 5, 2020
    DMaarten likes this.
  15. dantusris
    dantusris , via OnePlus 7 Pro , May 5, 2020 :
    Insufficient testing and incomplete use cases. Agile release not done right.
    AnonymousWP likes this.
