101
An update about Open Beta 12 for OnePlus 7 Pro and 7
  1. _Salman_Sallu_
    Donut May 7, 2020
  2. _Salman_Sallu_
    Donut May 7, 2020
  3. Godfather 1
    Jelly Bean May 7, 2020
    Godfather 1 , via OnePlus 6 , May 7, 2020 :
    it looks good now
    F_Adam_Graver_Htsz likes this.
  4. Godfather 1
    _Salman_Sallu_ likes this.
  5. F_Adam_Graver_Htsz
    Donut May 7, 2020
  6. angeltudela
    Cupcake May 7, 2020
    angeltudela , via OnePlus 7 , May 7, 2020 :
    Actualicé a la beta 13 hace una hora, notificación de actualización directamente en los ajustes del móvil.
    Por el momento todo Perfecto
  7. MadyKarthi
    Honeycomb May 7, 2020
  8. VaibhavBhargava
    Lollipop May 7, 2020
    VaibhavBhargava , May 7, 2020 :
    I would also agree back in the OnePlus 3 days the beta also used to more frequent. OnePlus tries to bring new feature updates everytime with the software updates especially for the stable branch.
    But, it would be better if they had a security update cycle and a feature update cycle across all supported devices.
    BeingIncog likes this.
  9. dsmonteiro
    Community Consultant Staff Member May 7, 2020
    Stickied Post
  10. Last edited by a moderator: May 7, 2020
    Syrix likes this.
  11. Syrix
    Gingerbread May 7, 2020
    Syrix , via OnePlus 7 Pro , May 7, 2020 :
    After flashing Pixel Experience, I see what you mean. They're close to that too.
  12. Syrix
    Deactivated User likes this.
  13. gianluigino
    Eclair May 7, 2020
  14. Swejuggalo
    OnePlus 9 Series Expert Community Expert May 7, 2020
    Swejuggalo , via OnePlus 7 Pro , May 7, 2020 :
    Isn't that "work life" and not dark/light?
    I had that pop up myself on beta at random moments. If I recall correctly the symbol looked like that. Haven't seen it since a long time.
    gianluigino likes this.
  15. gianluigino
    Eclair May 10, 2020
    gianluigino , May 10, 2020 :
    On OB 13 for OnePlus 7, I noticed that when the screen is locked (and off) for a long time the single tap or/and double tap to turn on the ambient mode or the lock screen doesn't work. the only way to turn on the screen is power botton.
    I have tried wipe cache but nothing changes. Maybe hard reset can solve but, actually I can't loose my files
  16. Swejuggalo
    OnePlus 9 Series Expert Community Expert May 10, 2020
    Swejuggalo , via OnePlus 7 Pro , May 10, 2020 :
    Seems to be common on 7. Might even have seen some on 7 Pro having it too... Uncertain if it can be a 6GB thing or more random and more common on all 7.
    If you haven't done so yet use the feedback tool to report it.
  17. gianluigino likes this.
