11
Working Android 10 Bluetooth codec not working. Qualcomm aptx
  1. madmax.dx
    Gingerbread Nov 17, 2019
    madmax.dx , via OnePlus 6T , Nov 17, 2019 :
    rolled back to pie OB17 from manual A10 OB1 upgrade ... recently upgraded to A10 OB1 via OTA..so far haven't faced the aptx codec issue in lenovo ht10...i may be wrong in longer run ..but so far so good
  2. LOVEABLEKRISH
    Cupcake Nov 20, 2019
  3. V1574368439168
    Cupcake Nov 21, 2019
    V1574368439168 , Nov 21, 2019 :
    I dont know if it will work with one plus devices or not even sure if one plus have this option... but go to bluetooth settings-> advanced-> turn off dual audio and then try to switch the codec.
  4. PaskSav83
    Cupcake Nov 23, 2019
    PaskSav83 , Nov 23, 2019 :
    I tried the bliss rom on aosp basis of Android 10 and it works perfectly. Has anyone tried the beta 6 for Oneplus 7/7 pro?
  5. TimNv
    Donut Dec 1, 2019
  6. chandan_choudhary
    Eclair Dec 2, 2019
  7. Klip1234
    Cupcake Dec 2, 2019
    Klip1234 , Dec 2, 2019 :
    Had the same problem....just updated to beta 06 and hour ago. Now by PX7 Works with atpx HD.
  8. nickky
    Donut Dec 12, 2019
    nickky , Dec 12, 2019 :
    Absolutely the same with vivo tws earphones! Oneplus 6t and android 10 beta 31
  9. LysakVitaliy
    Cupcake Dec 19, 2019
  10. trumpet78
    Gingerbread Dec 28, 2019
  11. A1580201336814
    Cupcake Jan 28, 2020
    A1580201336814 , Jan 28, 2020 :
    Just got my Sabbat E12 Ultra, and get the same problem with not working aptx even on the stable OS release.
  12. reonarudo29
    Cupcake Jan 30, 2020
    reonarudo29 , Jan 30, 2020 :
    OP6(A6000_22_191214)(OS 10.3.0)
    Radsone ES100(SBC,AAC,aptX,HD,LDAC)
    bluetooth audio codec menu in developers setting not working.
    Fixed to LDAC and cannot be changed.
  13. PC1995
    Cupcake Feb 22, 2020
    PC1995 , Feb 22, 2020 :
    Same problem with OnePlus 7T and 1More TW earbuds. I hope OnePlus is working on a fix for this. If they're pushing for wirelss audio they should atleast make sure that it works properly on their devices.
  14. cardobar
    Cupcake Mar 6, 2020
    cardobar , Mar 6, 2020 :
    I have the same problem in OP6 and Android 10.3.1, and I've found a solution, but you need root:
    You have to edit build.prop. Find line "persist.vendor.btstack.enable.splita2dp" and set it to false, then reboot.
    After that, my Creative Outlier are recognised as one device (not 2 separated devices) and I am able to choose aptx in the bluetooth configuration.
    mathewthomas84 likes this.
  15. Negro1983
    Donut Aug 27, 2020
    Negro1983 , Aug 27, 2020 :
    thanks but this cannot be the solution....OP remains silent and expects users to root their phone in order to edit a build.prop file...
  16. fieldcar
    Cupcake Oct 5, 2020
    fieldcar , Oct 5, 2020 :
    The solution is to go to developer options, and manually adjust the codec, and the trick is to set to the sample rate to what is supported by that codec. I recall this being automatic on older builds of oxygenOS, but now it just holds the last codec until you choose the supported bitrate and samplerate.
    For example, if you want AptXHD, you need to select 44.1 and 24bit. Want aptx? Select 44.1 or 48 KHz and 16 bit.
