222
Android 11 Beta (Developer Preview) for OnePlus 8 Series
  1. karvermas
    Eclair Jul 21, 2020
  2. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jul 21, 2020 :
    https://forum.xda-developers.com/oneplus-8-pro/how-to/op8pro-unbrick-tool-to-restore-device-t4084953
    Or
    https://forum.xda-developers.com/oneplus-8/how-to/op8-unbrick-tool-to-restore-device-to-t4085877
    Depending on device
    Might fix it via wiping in recovery too and then use the rollback package found in the Developer Preview
    ZulfekarSiddiqu likes this.
  3. Sorwin
    Donut Jul 21, 2020
    Sorwin , Jul 21, 2020 :
    Thanks! I'll wait until tomorrow to see if they can possibly fix the issue on their side since it seems multiple people are now having this issue. If not, I'll give it a try.
    edit: Also no, the full wipe does not help. As soon as the device has an internet connection it goes into a boot loop. Two other users (so far) confirmed the same issue.
  4. Rastko13
    Cupcake Jul 21, 2020
    Rastko13 , via OnePlus 8 Pro , Jul 21, 2020 :
    I had the exact same experience on OnePlus 8 and OnePlus 8pro last night.
    I managed to erase everything in factory recovery, and install rollback 10. Android (without turning WiFi on) on 8pro. Now it works. But the OnePlus 8 is 2010 (Chinese) so it doesn't accept any rollback ROM.
    Any ideas?
  5. Rastko13
    I downloaded the downgrade ROM on computer and transferred it to OnePlus 8 pro over USB flash . Just don't activate WiFi and don't register Google in setup.
    Swejuggalo likes this.
  6. Rastko13
  7. Sorwin
    Donut Jul 21, 2020
    How can I downgrade though? I'm stuck on the setup screen. There is no Skip option in the WiFi, they force it.
  8. Rastko13
    If it is a OnePlus 8 pro you can enable WiFi but don't register Google and don't allow any registrations (pin, screenlock etc). Take out SIM card
  9. G_pankaj_khatwani_pzau , via OnePlus 6 , Jul 21, 2020 :
    Hey one plus I'm big fan I'm buying every gen of your new phones but I have stopped after OnePlus 6 I don't as I'm software guy rather than just hardware I'm seeing a new trend in your phone's just latest chip little bit camera that's it but prices are jumping like rocket I really wanna see some software improvements too i have secondary iOS phone I wanna suggest you one software termeed as guided access in iOS what it's does that u can turn on guided access while particular app and to come out of that app you need to put password that's the best feature I have seen it comes really handy when you hand over your phone to others for some work I hope you take this as consideration thank you always OnePlus lover[e]2764[/e]️
  10. Sorwin
    Donut Jul 21, 2020
    I can't, as soon as I connect to any WiFi, the phone goes into a boot loop, which is once again, the same issue others are having.
  11. richardshaylor
    richardshaylor , Jul 21, 2020 :
    Hey I also experienced this last night too. I also ended up using the msm tool. Seems a bit of a coincidence that its happened to more the one person around the same time. Did you all also happen to be on version 1?
  12. Sorwin
    Donut Jul 21, 2020
    Honestly, I'm not sure - I downloaded whatever was linked here: https://forums.oneplus.com/threads/android-11-beta-developer-preview-for-oneplus-8-series.1233995/ about 2 weeks ago. I mostly wanted to get dual sim working so I did not pay attention to the version at the time.
  13. Sorwin
    Donut Jul 21, 2020
  14. mischa1981
    Ice Cream Sandwich Jul 21, 2020
  15. Soulsurfer919
    Honeycomb Jul 21, 2020
    Soulsurfer919 , via OnePlus 8 Pro , Jul 21, 2020 :
    Nice to see development of android 11 on 8 series. Very glitchy system with lot of UI elements out of place and apps misbehaving so back to stable again.
    Liked the new font used in android 11 that was the one thing I liked the most. Hoping next beta is will be better.
  16. tko8787
    Eclair Jul 21, 2020
    tko8787 , via OnePlus Community App , Jul 21, 2020 :
    Yes use oxygen uodater and choose the one you want ... How were you able to install it on your phone from PC
  17. petronijus
    petronijus , via OnePlus 8 , Jul 21, 2020 :
    Another OnePlus fail. Does not matter if it is developer preview or not, when it does not boot, it is a brick. Had to use unbrick tool to get it back to work on Android 10.
  18. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jul 21, 2020 :
    As far as I know it's Google components that is updated during the setup. It's always good to expect the unexpected and be prepared to wipe via adb
  19. Marcoleus88
  20. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jul 21, 2020 :
    Currently users is suffering by bootloops that does not even recover with a wipe... Don't know if that applies to both DP1 and DP2
