Android 11 BT calls on OnePlus 7T Pro
  1. alexpc73
    Eclair Apr 13, 2021
    alexpc73 , Apr 13, 2021 :
    Hi,
    after installing the latest OS version for the 7T Pro, Android 11, the behaviour of the call system is not working fine.
    I always have a smartwatch connected with BT capability to answer/perform calls (Huawei Watch GT2 Pro) and I usually wear some BT headsets (Xiaomi, Sony or Cardo System) when I do my workouts (usually running) or when I ride my motorbike.
    If I've got an incoming call, the BT device is always the smartwatch or the Phone, never the headset. If I want to perform an outgoing call, is it always the phone and not the BT Headset connected.
    This never happens before with the Android 10 version... so I don't know why is this happening now. I just remove the data and cache from the call app, but this also didn't fix this weird behavior.
    Did someone check this?
  2. J4t1np4r3kh
    OnePlus Accessory Tester Apr 13, 2021
  3. McLarenMania
    Gingerbread Apr 15, 2021
    McLarenMania , via OnePlus 7T Pro 5G , Apr 15, 2021 :
    The call should be notified on both your headset and watch and when your BT head set should have the ability to answer the call. If not try unpairing and install the BT headset again
