318
Android 11 Developer Preview 3 with OxygenOS 11 Design and Features for the OnePlus 8 Series
  1. hk_o2
    Honeycomb Aug 11, 2020
    hk_o2 , Aug 11, 2020 :
    same
  2. SairaamS
    Cupcake Aug 11, 2020
    SairaamS , via OnePlus 7 Mirror Gray , Aug 11, 2020 :
    Ching_Nam_Ip
    I set font to smallest
    and I use thrid party battery bar on the camera arc so i disable the original batery bar
    Thank you so much, mate..[e]1f60a[/e]
    The app name for that battery bar please?
  3. avila58
    Froyo Aug 11, 2020
    avila58 , Aug 11, 2020 :
    I did it just now. Honestly, it works very well, so far I haven't encountered any problems with the apps. We will continue to see and wait for updates that may correct some less pleasant situations.
    Very well team from OnePlus. Never Settle
    Sinnaz0709 likes this.
  4. wleonardocruz
    Gingerbread Aug 11, 2020
  5. wleonardocruz
    wleonardocruz , via OnePlus 8 Pro , Aug 11, 2020 :
    Anyone have my problem the writing line is hidden in WhatsApp and messenger.
    Fix: Unhide the bottom bar fix the problem
    this fix is posted for one guy in comment ahead.
  6. matthew.dattilo
    Froyo Aug 11, 2020
    matthew.dattilo , Aug 11, 2020 :
    I'm using Nova for my launcher, so I can't speak to the font issue. The only thing I'm seeing as a problem so far is the keyboard when using gestures...basically, it blocks the field in which you are typing in text apps. I turned off gestures and that fixed the problem. However, I've gotten used to not having the three buttons at the bottom of the screen.
    Overall, very happy considering this is a developer preview!
    wleonardocruz likes this.
  7. GaneshKunte
    Froyo Aug 11, 2020
  8. matthew.dattilo
    Froyo Aug 11, 2020
    Yes. Turn off gestures and the problem will go away. Not a perfect solution, but it works.
  9. GeloTheGreat
    Froyo Aug 11, 2020
  10. hk_o2
    Udit2508 likes this.
  11. Mobpsy
    Froyo Aug 11, 2020
  12. GeloTheGreat
    Froyo Aug 11, 2020
    GeloTheGreat , via OnePlus 8 Pro , Aug 11, 2020 :
    show the navigation bar. thats the only way to fix from now.
  13. SATYAVEER KUJUR
  14. GaneshKunte
    Froyo Aug 11, 2020
  15. Lemillion
  16. hk_o2
  17. Dhruv Kashyap
    Ice Cream Sandwich Aug 11, 2020
    Dhruv Kashyap , Aug 11, 2020 :
    Eagerly waiting to get my hands on the latest build for OnePlus 7T as soon as it is launched!!
    OnePlus's OxygenOS11 * Android 11 looks just superb.
    f0li0 likes this.
  18. Udit2508
    Udit2508 , via OnePlus 7T , Aug 11, 2020 :
    Ching_Nam_Ip
    New widget
    Thank you for posting all the pics and giving us first look of the Android 11. I am currently on open beta on oneplus 7t. So my doubt is that will i get the beta version or the stable version of Android 11 ???whenever it comes.
    Ching_Nam_Ip likes this.
  19. hk_o2
    you are welcome
  20. MarkNorthgraves
