316
Android 11 Developer Preview 3 with OxygenOS 11 Design and Features for the OnePlus 8 Series
  1. Rahulreddy@2004
    Cupcake Sep 11, 2020
    Rahulreddy@2004 , via OnePlus Nord , Sep 11, 2020 :
    Gays pls reply and solve????
  2. F1591691059387
    F1591691059387 , via OnePlus 8 , Sep 11, 2020 :
    Same problem bro
    itz_mohitraj likes this.
  3. Tee_Eee_Bee
    Ice Cream Sandwich Sep 11, 2020
    Tee_Eee_Bee , Sep 11, 2020 :
    Settings > display > Advanced > Apps to Display in Fullscreen
    Find your app and check the settings, change to full screen (if not already) and see if it makes a differerence.
    If it is already set to full screen, the app may not support full screen display at thistime.
  4. bassukonek
    Cupcake Sep 13, 2020
    bassukonek , via OnePlus 8 , Sep 13, 2020 :
    No, but if u want to goback stable version Android 10 everything goes so keep backup
  5. N1593679741757
    Eclair Sep 13, 2020
  6. Bippoptl
    Eclair Sep 14, 2020
    Bippoptl , Sep 14, 2020 :
    Ok so how do you know if you bricked the phone? Mine is stuck on the red dot with the white dot spinning around it, but the dots are frozen
  7. Daniele_Riccio
    Cupcake Sep 14, 2020
    Daniele_Riccio , Sep 14, 2020 :
    I got the BETA 1, and have serious problem for battery drain and recharge (specifically it seems that the warp charge doesn't work at all).
  8. 123dhrv
  9. Tee_Eee_Bee
    Ice Cream Sandwich Sep 14, 2020
    Tee_Eee_Bee , via OnePlus 8 Pro , Sep 14, 2020 :
    Search for the msm download tool for your device, it's usually found on xda developers.
    Caomhin likes this.
  10. Tee_Eee_Bee
    Yes it is, but this version is for the 8 series, so you you can't use it for a 7 series device.
    Caomhin likes this.
  11. Rahulreddy@2004
    Cupcake Sep 15, 2020
    Rahulreddy@2004 , via OnePlus Nord , Sep 15, 2020 :
    I am facing huge network problem in by one plus nord. when someone call me I do not recive all the calls some calls will be missed.[e]1f62d[/e][e]1f62d[/e][e]1f62d[/e][e]1f62d[/e][e]1f62d[/e]
    Pls solve this problem .
    This is not only my problem many users are facing.
  12. pankajkr.pk
  13. F_Chik_Chik_MoRry_mtAN
    Cupcake Sep 18, 2020
  14. F1591691059387
    Cupcake Sep 19, 2020
  15. F1591691059387
    Cupcake Sep 21, 2020
    F1591691059387 , via OnePlus 8 , Sep 21, 2020 :
    Hey bro wat happen have u roll back to android to 10
  16. N1593679741757
    Eclair Sep 21, 2020
  17. Tee_Eee_Bee
    Ice Cream Sandwich Sep 21, 2020
    Tee_Eee_Bee , Sep 21, 2020 :
    If this is anything like Open Beta 1, then this is a "Global" software version that does not have the region specific features like scout etc. that are offered in India
  18. Jere1992
    Cupcake Sep 22, 2020
    Jere1992 , Sep 22, 2020 :
    I have three very strong complaints on the OnePlus 8:
    1- The battery drains a lot. It went from giving between 9 and 10 hours of screen to giving between 6 and 7 hours. It's A LOT. And these values are without activating the AOD.
    2- The automatic switch from 90hz to 60hz on dark backgrounds, it shows a LOT, and it is really very annoying, both in terms of slowness and that the screen changes color, becomes more gray.
    3- The dark mode is gray instead of being black as in OxygenOS 10. Please fix that urgently, the rest are minor faults that don't bother you much on a day-to-day basis.
    Regards.
    Daniele_Riccio likes this.
  19. Bend66
    Donut Sep 24, 2020
    Bend66 , via OnePlus 8 Pro , Sep 24, 2020 :
    Hi,
    Updated to the beta 2 on oneplus 8 pro and il having the following issues :
    Screen auto brightness too dim.
    Proximity sensor not working (screen not turning off during a call)
    Sometimes gestures do not work anymore .
    Are those known issues ?
    Thank you
  20. Lotboyz757
    Cupcake Sep 24, 2020
