316
Android 11 Developer Preview 3 with OxygenOS 11 Design and Features for the OnePlus 8 Series
  1. Mazharapps
    Gingerbread Aug 11, 2020
    Mazharapps , via OnePlus 8 Pro , Aug 11, 2020 :
    Couple of observation in last 3 hours
    1. Home screen time, lockscreen, always on display time are showing 24 hours format even if it is not enabled
    2. Using gestures for navigation is blocking / hiding which texts are writing in any apps (checked FB messenger, whatsapp). If you disable gestures & use buttons for navigation, you can see the texts while writing.
    3.themes are removed. So, as earlier there is a theme where icons can be seen as natural, not round & cropped, it's not showing now. A cropped icon looks always weird.
    4. Battery drainage seems high.
    5. Installed oemlogkit to enable volte option under sim & network. But cannot go to the menu after dialling *#800#
    6. Difference between 2 fonts option are too little.
    7. there was switch option to google shelf and oneplus, which is missing here
    8. cannot sign in to Uber app. after inserting phone number, it's couldn't send verification code on time
    9. oneplus bullets 2 got connected easily but there is prompt coming at the notification to tap qualcomm aptx to select but nothing happens when tapped
  2. Mazharapps
    Harish ahamed likes this.
  3. X1597077747588
    Cupcake Aug 11, 2020
  4. kanchansill12121
  5. Harish ahamed
    Donut Aug 11, 2020
  6. yashwant24
    OnePlus Accessory Tester Aug 11, 2020
    X1597077747588 likes this.
  7. Shailesh pratap
  8. Harish ahamed
    Donut Aug 11, 2020
  9. yashwant24
    yashwant24 , via OnePlus 6 , Aug 11, 2020 :
    That's why it is called developer preview and you must face it.
    ritesh808 and Shailesh pratap like this.
  10. mskubenko
  11. Meylanx
    Donut Aug 11, 2020
  12. grymster
    Froyo Aug 11, 2020
    grymster , Aug 11, 2020 :
    Three times per page :(
    KarthikvChandra and yashwant24 like this.
  13. yashwant24
    Probably it won't this year.
    You might get a direct beta and then a stable update.
  14. yashwant24
    grymster likes this.
  15. Leon Lwd
    Donut Aug 11, 2020
    Leon Lwd , Aug 11, 2020 :
    I use it on the oneplus 8 pro it looks the same as the samsung one ui, need more oneplys style.
    Calculator bugs.
    icons bugs.
    always on go to the left / center ect if u dont use u phone give the option to center it if u not use the phone.
  16. p2p
    Honeycomb Aug 11, 2020
    p2p , Aug 11, 2020 :
    I was thinking exactly that seeing the screenshots.
    The new look is more like MIUI or ONE UI. OxygenOS is turning into a too much customized rom far from what is nowadays.
    abhinandanjain09, NateDev and arknu like this.
  17. p2p
    The 5 series have reached their EOL (End Of Life)
    Hey, you have had THREE major updates (8, 9 and 10). What more do you want? Enjoy that 5T running android 10.
    NateDev likes this.
  18. Vbj_OP_7
  19. yashwant24
    You can find third party apps like energy ring.
  20. jmendozanunez
    Froyo Aug 11, 2020
