321
Android 11 Developer Preview 3 with OxygenOS 11 Design and Features for the OnePlus 8 Series
  1. HeadphonesNeil , via OnePlus 8 Pro , Aug 12, 2020 :
    So after using DP3 for half a day overall performance is good and most of the apps I use work. The only issues I've found are...
    1. Random sluggish touchscreen
    2. Google Pay, Disney+ and Netflix don't work
    I got a boot loop when doing a direct upgrade from stock Android 10 so did a clean install and imported my Google backup from the cloud at initial setup
    F_Brandon_Tobias_jGSG likes this.
  2. Chirag bajaj
    Froyo Aug 12, 2020
    Chirag bajaj , via OnePlus 8 Pro , Aug 12, 2020 :
    Ok this just got ugly. The Whole point for this was to get fresh new design but OnePlus did screw up in the near stock android experience department.
    That grey background kind of dark mode with oxygen os 11 isn't any better in the aspect of battery improvement.
    Who else think oxygen os 10 was way better.
  3. Alejandrofdez343
    Froyo Aug 12, 2020
  4. Bigmike1985
    Donut Aug 12, 2020
  5. damiansixx
    Eclair Aug 12, 2020
    stavros67 and F1536011049830 like this.
  6. Attached Files:
  7. hk_o2
    Honeycomb Aug 12, 2020
    hk_o2 , via OnePlus 8 , Aug 12, 2020 :
    Take a backup for safety precautions
    Normally it won't wipe your data
    X1576723916553 likes this.
  8. X1576723916553 , via OnePlus 8 Pro , Aug 12, 2020 :
    My whatsapp backup is more then 3 gb bro...
    What else should I do ??
    And photos I moved to lockbox then is it also wiped ???
  9. Omar322
    Froyo Aug 12, 2020
    Omar322 , Aug 12, 2020 :
    Some errors in terms of touch seem quite good to me sometimes if you are in WhatsApp you have to press several times to write more, the writing bar in most apps appears under the keyboard and does not let you see what is written
  10. rinkimekari
    Gingerbread Aug 12, 2020
    f0li0 likes this.
  11. hk_o2
    Unm if you have a computer copy once to your computer
    Whatsapp backup just upload it to Google drive you have no other choice
    Or else don't try DP version as there is a risk
  12. X1576723916553 , via OnePlus 8 Pro , Aug 12, 2020 :
    Okie bro I will take backup.....
    Thanks
    Is it working gud or wat ??
    Android 11 or os 11 ??
  13. X1576723916553 , via OnePlus 8 Pro , Aug 12, 2020 :
    This is miner error o think...
    Everyone can manage
  14. Atul Menon
  15. hk_o2
    It is Android 11 and oos 11
  16. Atul Menon
    beju_imba likes this.
