3
Third Party Software Android 11 makes auto focus on google translate not work anymore
  1. efencer
    Cupcake Aug 15, 2021
    efencer , Aug 15, 2021 :
    I updated to Android 11 on 14/8/21, and now google translate is not able to auto focus.
    cmj556, xfranky and X1630233738135 like this.
  2. Overzee
    The Showcase Reviewer Aug 15, 2021
    Overzee , Aug 15, 2021 :
    And this is the stable version of OxygenOS 11 (Android 11)?
  3. Dan_Andresan
    Cupcake Aug 16, 2021
    Dan_Andresan , Aug 16, 2021 :
    I am not the original poster, but I have exactly the same problem.
    Google Lens and Google Translate do not focus anymore, since the update to Android 11, on my OnePlus 6T.
    It is the stable version, updated from official OxygenOS 10 (never had any beta version). In OxygenOS 10 the applications worked perfectly!
    As a workaround, I take the picture using the official Camera app (were autofocus works without any problem) and then use Google Lens (or Google Translate) on it. But it is an ugly workaround, it takes time...
    Please ask if more info is needed, I will gladly provide it.
    Thanks,
    Dan.
  4. DGangJ
    Donut Aug 17, 2021
  5. X1630233738135
    Cupcake Aug 29, 2021
  6. gandadil
    Cupcake Aug 31, 2021
    gandadil , Aug 31, 2021 :
    I have the same problem too. I am trying to scan a QR code but I can't. I have to scan in other app. I think that Google apps trying to acess the background blur like on portrait camera mode, so the image will never be focused.
  7. xfranky
    Cupcake Sep 2, 2021
  8. efencer
    Cupcake Sep 5, 2021
    efencer , Sep 5, 2021 :
    Yes, it is the official version. As reported by other people in this thread, there are more applications affected by this, all that need the camera and normally have auto focus.
  9. deeneendo
    Donut Sep 7, 2021
    deeneendo , Sep 7, 2021 :
    Oneplus 6 on Oxygenos 11 here. same problem, it is a shame that it takes so long to fix this issue.
  10. RolandManders
    Cupcake Sep 7, 2021
    RolandManders , Sep 7, 2021 :
    Also latest 11 version on Oneplus 6. Focussing not working. Tapping does not work. It is really anoying.
    terveg likes this.
  11. efencer
    Cupcake Sep 16, 2021
    efencer , Sep 16, 2021 :
    I had some other occurrences today, one was via a webpage I needed to scan an ID, and the auto focus did not work. Other apps also did not function properly.
  12. terveg
  13. RolandManders
    Cupcake Sep 27, 2021
    RolandManders , Sep 27, 2021 :
    Is there news when this issue will be solved? It is now almost 1.5 months and still no solution?
