68
Android 12 Developer Preview 2 for OnePlus 9 and OnePlus 9 Pro
  1. Abdul B.
    OxygenOS Operations Staff Member Sep 28, 2021
    Abdul B. , Sep 28, 2021 :
    Hey everyone,
    The Android 12 Developer Preview 2 is now available for the OnePlus 9 and OnePlus 9 Pro!
    By providing access to Developer Preview at an early stage, we enable app developers and other early adopters in our community to start creating even better software experiences. For more information, please refer to
    https://www.oneplus.com/os/developer-preview/android12
    As the name suggests, this build of Android 12 is best suited for developers and other advanced users, as it is still in an early stage of development. That said, we do not recommend flashing this ROM if you have little to no experience in software development, if you expect to use the device as a daily driver, or if you have no experience flashing custom ROMs. Proceed at your own RISK!
    Update log
    • System
      • Optimized the auto-brightness algorithm to adapt screen brightness to more scenes for a comfortable screen reading experience
      • Optimized the mistouch prevention algorithm for curved screens to reduce accidental touches
    • New design
      • Added widgets that show key information of apps and provide instant access to functions
      • Optimized the page layout and the presentation of text and color to make key information stand out
    • Convenience & efficiency
      • Added swiftly switch floated windows, make operation more convenient
    • Games
      • Optimized the frame rate performance under heavy-used scenes
    • Camera
      • Added the feature that supported customize the display order of camera mode
      • Optimized the zoom experience, make it zoom more smoothly
    • Performance
      • Added the form of chart to display battery usage
      • Newly supported pre-loading the apps that frequently used, to switch them on quickly
      • Improved the response speed of turning on or off Wi-Fi, Bluetooth, Airplane mode, and NFC
    Known Issues
    1. The Camera does not support Xpan, and contains some stability issues
    2. This version does not support scrolling screenshot
    3. The icon of Bluetooth connection displays abnormally
    4. The icon of charging displays abnormally
    5. The Cloud Service is unavailable (India)
    6. The Camera app does not contain Hasselblad elements
    7. This version is not compatible with some third-party apps
    8. The included Google Phone app does not feature call record functionality. This can be solved by updating the app in Play Store.
    9. Three-finger swipe down gesture or three-finger long-press gesture after using the screen recorder. This can be overcome by pressing Power button and Volume Down button simultaneously instead to screenshot.
    Caution!
    You should understand there is a risk of BRICKING your phone, read the instructions carefully and be 100% sure of what you are doing. Please always backup your important data before flashing.
    Please note:
    1. These instructions are only for the OnePlus 9 and 9 Pro. Please make sure the battery level is above 30% and a minimum 3GB of storage space is available.
    2. Carrier version devices (TMO/VZW) aren't compatible with the Developer Preview builds.
    MP version – Stable official version
    DP version – Developer Preview version
    OBT Version – Open Beta version
    MP and OBT to DP upgrade guide—via Local OTA Update
    Note: This upgrade method will erase all the contents of the phone, please be sure to backup first.
    1. Download the latest ROM upgrade zip package from the specified server.
    2. Copy the ROM upgrade package to the phone storage.
    3. Go to Settings -> System -> System Updates -> Click top right icon -> Local upgrade -> Click on the corresponding installation package -> Upgrade -> System upgrade completed to 100%.
    4. After the upgrade is complete, click Restart.
    5. Update successful.
    DP to MP rollback guide - via Local OTA update
    2. Copy the Rollback package to the phone storage.
    3. Install this apk. You'll need it to rollback. Then, open the app -> tap the top right gear icon -> find the downgrade package and tap it -> wait to finish the installation -> tap reboot
    Ready to get started on the OxygenOS DP2 Beta?
    Want to go back to Android 11? Download the Rollback package from the links below:
    This is an early Developer Preview build to give developers an early chance to test their apps with an upcoming Android version. As such, its main purpose is not to collect bugs. If you want to provide feedback about any bugs you face with this build, you can use the built-in feedback APP.
    Still, your feedback is appreciated. We may not always be able to respond to every comment in the forums, but please be assured that we take your comments and feedback seriously. Hope you enjoy and let us know how you feel about the update in the comments below.
    Never Settle.
  2. dsmonteiro
    Community Consultant Staff Member Sep 28, 2021
    Stickied Post
    dsmonteiro , Sep 28, 2021 :
    Update: Due to stricter EU policies, we currently cannot supply an EU-specific build. However, as @derLenno already shown above, installing the NA build works if you want to test out the Developer Preview ahead of the Open Beta builds.
    We have provided an EU rollback build for your convenience.
  3. derLenno
    The Lab² - Oclean X Pro Elite Reviewer Sep 28, 2021
    derLenno , Sep 28, 2021 :
    Yeeee boyyyy
    I flashed this. This is NOT daily driver material!
    edit: Already found my new favourite feature 😂😂
    edit 2: pic dump
  4. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert Sep 28, 2021
  5. Shubham_Ag.
    Jelly Bean Sep 28, 2021
    Caomhin, Artemus and Dresa91 like this.
  6. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Community Expert Sep 28, 2021
  7. ItsNexor
    Honeycomb Sep 28, 2021
    Dresa91 likes this.
  8. matthu.2711
    The Lab - OnePlus 7 Pro Reviewer Sep 28, 2021
  9. ItsNexor
    ItsNexor , Sep 28, 2021 :
    You can't because of EU strict policies
    G_plusone and Dresa91 like this.
  10. derLenno
    derLenno , via OnePlus 8T , Sep 28, 2021 :
    I'm running the NA stable build anyways. 😅
    You can bet your sweet Finnish butt on that!
  11. Liehjan
  12. ItsNexor
    Dresa91 likes this.
  13. YRJ
    The Lab - OnePlus 7T Reviewer; Community Hero 2020 Community Expert Sep 28, 2021
  14. Liehjan
  15. Huigiebaby
    Ice Cream Sandwich Sep 28, 2021
    Huigiebaby , Sep 28, 2021 :
    Don't bother, too many known issues and probably even more unknown...
    edit:
    + Open beta probably in a few weeks
    + To go from this to Open beta will probably delete all your data -> again.
    YUX, northbay5566, G_plusone and 2 others like this.
  16. YRJ
    YRJ , Sep 28, 2021 :
    I want to but I don't have a good feeling about this :sweatsmile:
  17. gaster
    Moderator Moderator Sep 28, 2021
  18. Aaron2017
    Lollipop Sep 28, 2021
  19. A.Saketh Gupta
  20. dsmonteiro
    Hey everyone,
    Thank you for the questions from our European users regarding the lack of an European-specific build. I've already contacted the software team about this and I will update you guys as soon as possible.
    Thank you for your patience.
