Hammer4all , via OnePlus 9 Pro , Jan 26, 2022 : I swapped from OP8 Pro to 9 Pro two weeks ago, really satisfied! Today an update came, it turned out to be Android 12. Phone is really buggy now: - Can't open Assistant, just blinks and disappears. - Home virtual button must be clicked several times and then suddenly it works and I get back to start screen. - L2TP/IPSEC is gone, I need it to connect to work, catastrophe. Overall, a really bad experience...and for the first time in many years, I consider an Iphone. I have had OP since 5, så this is a hugh disappointment. 😭
Swejuggalo , via OnePlus 9 Pro Morning Mist , Jan 26, 2022 : Is the assistant set as default assistant? Tried a reboot? Don't see this?
Hammer4all , via OnePlus 9 Pro , Jan 27, 2022 : Where do I set it to default? I mean, it's flickering...so it's there someway? And what is this Qualcomm voice? Sounds the same as Google Assistant? But turned on all the time, I don't want that, I want push and talk. VPN, yes but that is not L2TP. Google seem to have removed that in 12. My company router only support L2TP.
