Android 12 ox problems
does anyone have the same problems
  1. Yes
    100.0%
  2. No
    0 vote(s)
    0.0%
  1. Q1636749823700
    Cupcake Jan 25, 2022
    Q1636749823700 , Jan 25, 2022 :
    Can't turn off google discovery after update. I couldn't remove it from the home screen in any way. another problem, guest user session is not deleted in any way and I can't remove it,this is ridiculous. it is not named, deleted, closed, it just stays in the notification panel.Also why did you remove the round battery bar?
  2. Aaron2017
    General Support Expert Award 2021 Jan 25, 2022
    Aaron2017 , Jan 25, 2022 :
    For Google discover, you can turn of the news feed in Google's settings itself but you would still have the Google search bar at the top of that left page. Alternatively you could use a third party launcher too, like Nova launcher or lawnchair launcher for example.
    Not really an explanation as to why they removed the round battery style but here is what they said about it in the FAQ thread
    https://forums.oneplus.com/threads/oxygenos-12-faq-find-your-answer.1519491/
    You can give them your feedback about it, and about the guest account as well, here if you want
    Shailender Sharma likes this.
  3. F_Fabricio_Pontes_kQaI
  4. Aaron2017
    As i said above, you can disable the news card by opening google app>tap on your profile picture>settings>general and disable Google discover there. But you would still have the left page with the Google search bar at the top. Only other way is to use a third party launcher
  5. F_Fabricio_Pontes_kQaI
    F_Fabricio_Pontes_kQaI , Jan 25, 2022 :
    I did that and now I have an empty screen with the Google search... But on previous versions it was possible to get rid of this annoying screen. Please ask the developers to add a toggle to remove this screen.
  6. Aaron2017
    Yeah, completely disabling it isn't an option anymore. I'm just a user, i have no direct line to the developers whatsoever, but you can give them feedback about it yourself. Open the community app>press the red + button and select feedback
