6
Android 6.0 on my Nexus 7... Awesome!
  1. marcyeo Ice Cream Sandwich Oct 7, 2015
    marcyeo, Oct 7, 2015 :
    I just installed Marshmallow on my 2013 Nexus 7 last night via flashing factory image. I must say it's much more better than Lollipop.. Smooth scrolling and animation.. Battery life seemed to be better than 5.1.1... Just gut feeling I don't know.. Higher frame rate when playing nfs, Asphalt 8 etc.. I wish that opo and op2 will hv 6.0 soon.. Pray
  2. #HYPEorGTFO KitKat Oct 7, 2015
  3. 00Shadow00 Honeycomb Oct 7, 2015
    00Shadow00, Oct 7, 2015 :
    Did the exact same thing to my Nexus 7 last night. I'm loving it too but I wish it had more features.
    Gaurav Rohilla and #HYPEorGTFO like this.
  4. marcyeo Ice Cream Sandwich Oct 7, 2015
    so far battery life has been much better
    #HYPEorGTFO likes this.
  5. marcyeo Ice Cream Sandwich Oct 7, 2015
    at least battery life is better and everything is smooth like when it was kit kat
    00Shadow00 likes this.
  6. marcyeo Ice Cream Sandwich Oct 7, 2015
    battery life is better...im getting 4 hours plus sot
  7. yahiroz Jelly Bean Oct 7, 2015
    yahiroz, Oct 7, 2015 :
    That's the magic of Doze.
    ... And Marshmallow is not avaliable for my Nexus 10. Nearly 2 years since I've had it but it still is a great performer.
  8. Artur Deus Gingerbread Oct 7, 2015
  9. joem01 Gingerbread Oct 7, 2015
    joem01, Oct 7, 2015 :
    I wiped my 2012 N7 last night, reflashed a factory image (just to clean everything up), did a twrp backup and then flashed CM12. Figured it's being left behind by Google, so it's time to move on to be able to get Marshmallow.
  10. aaron.hossain75 Lollipop Oct 7, 2015
  11. rathernicelydone Gingerbread Oct 7, 2015
    rathernicelydone, Oct 7, 2015 :
    Ugh my Nexus 7 died a couple of weeks ago after 2 years of exemplary service. Gutted.
  12. veratoloz2005 Lollipop Oct 7, 2015
  13. marcyeo Ice Cream Sandwich Oct 8, 2015
    marcyeo, Oct 8, 2015 :
    thats too bad man..i think custom rom would do the trick ;D
    yahiroz likes this.
  14. Skf123 Marshmallow Oct 8, 2015
    Skf123, Oct 8, 2015 :
    Just flashed the factory image on my nexus 5, seems to be pretty good so far.
    nyzproof333 likes this.
  15. FlatEric0074 Eclair Oct 8, 2015
  16. AntMunny KitKat Oct 20, 2015
    AntMunny, Oct 20, 2015 :
    You know i resisted flashing the stock factory image of marshmallow for the nexus 6, but i've heard nothing but good things about it.
    I was waiting for Marshmallow nightlies of CM.
    I hear getting r00t on stock Marshmallow is a huge ordeal
  17. frosty5689 Froyo Oct 21, 2015
    frosty5689, Oct 21, 2015 :
    Getting root on stock Marshmallow is as easy as flashing a SuperSU 2.50+ TWRP zip. As long as you got TWRP recovery, you're good.
    I flashed the TWRP version of the Nexus 5 Marshmallow factory image. The standby battery life and smoothness have improved. The Screen on time didn't get much better though. Got my OPT arriving tomorrow, hopefully it doesn't drain too much on standby.
  18. vijayvk84 Honeycomb Oct 21, 2015
  19. TechBiz Cupcake Jan 4, 2016
  20. prezes5 Ice Cream Sandwich Jan 6, 2016
