42
Android 7.0 nougat performance issues on OnePlus 3
  1. G_Raghav_Garg_GmZo
    Cupcake Jan 22, 2017
    G_Raghav_Garg_GmZo , Jan 22, 2017 :
    Did you find some solution? I am facing the same problem!!
  2. G_Raghav_Garg_GmZo
    Did the reset work?
  3. Malasadi
  4. G_Ali_Khan_CPVM
    Eclair Jan 22, 2017
    G_Ali_Khan_CPVM , Jan 22, 2017 :
    Go to settings... Advance.. And switch on pcket mode... Hopefully ur problem will b solved
    Basically if its off when the phone is in ur pckt it registers ur body accidental touches to ur fingerprint scanner and screen thus continuesly consumes battery
    chunku likes this.
  5. JoshuaGall1
    JoshuaGall1 , Jan 22, 2017 :
    I just updated mine to Nougat and found that performance noticably improved. Yours seems to be an isolated case
  6. chevellein
    chevellein , Jan 22, 2017 :
    Mine is not rooted... completely stock. last night I factory reset it to 51 days earlier. this seems to have fixed everything except the volume problem. I still can't lower the volume below 14. I had "go launcher" before and did not reinstall it. that may have been part of the problem.
  7. EvelyneMichiels123
    EvelyneMichiels123 , Jan 22, 2017 :
    I had the same problem. I had to do a factory Reset but now it works perfectly fine... So i am happy with the update although i need to install all apps again etc.
  8. chunku
    Donut Jan 22, 2017
    chunku , Jan 22, 2017 :
    Same here - I noticed this since upgrading...wish I hadn't upgraded - everything was solid before this..
    TrumpetMike likes this.
  9. wedajm
    wedajm , Jan 22, 2017 :
    I´m also having the heat issue. Before 7.0 my Oneplus3 didn´t feel hot at all. Now, when being idle on the table it feels pretty hot for doing nothing.
    I hope they will fix this soon
  10. wedajm
    I´m having the same issue. Very disturbing since my Oneplus3 was perfect before 7.0
    I check the processor cores, and they were running like crazy. Maybee that is the problem, or I might be wrong.
  11. Dhiren Gajwani
    Donut Jan 22, 2017
    Dhiren Gajwani , Jan 22, 2017 :
    Try restarting your phone same thing happened withe but after restarting all contacts came back
  12. thediskette
  13. Dhiren Gajwani
    Donut Jan 22, 2017
  14. TrumpetMike
    Eclair Jan 22, 2017
    TrumpetMike , Jan 22, 2017 :
    My op3t came last week and until yesterday i had MM not nougat.
  15. MkGriff1492
  16. G_Waqas_Ashfaq_gcev
  17. Vidi Sothu
    Vidi Sothu , Jan 22, 2017 :
    Mine's got this multi window issues where it gets hang/freeze and can't exit that particular app, kinda sucks Mann OP. Plz solve this ASAP.
  18. G_Raghav_Garg_GmZo
    Cupcake Jan 23, 2017
    G_Raghav_Garg_GmZo , Jan 23, 2017 :
    After updated Android nougat to my OnePlus 3. my contacts were lost. call logs are totally erased. unable to make call. unable to save new contacts. Can anyone help please? I can make any call but not save any contact!! My phone and contact application is not working!
  19. JoshuvaAntony
    Ice Cream Sandwich Jan 23, 2017
  20. G_Sebastiaan_van_Oppenra
    G_Sebastiaan_van_Oppenra , Jan 23, 2017 :
    I have have several e-mail accounts en only with my exchange account im experiencing the issue....I cannot see those contacts at all. but when i type in a phone number mannualy and press call i DO see the contact name
