42
Android 7.0 nougat performance issues on OnePlus 3
  1. BluSleeper Eclair Jan 29, 2017
    BluSleeper, Jan 29, 2017 :
    Same problem. Noticeably leggy after updating. Wonder if you had a Launcher too? I removed my Nova Launcher and it seemed to help. Don't know why. I guess they will patch this soon bec it's just the first release.
  2. BluSleeper Eclair Jan 29, 2017
    It depends on your country. You can download the whole package in the website and install manually.
  3. Jose Bisquert Cupcake Jan 29, 2017
    Jose Bisquert, Jan 29, 2017 :
    Hello all,
    My name is José. I bought a Oneplus 3t just a month ago because my old mobile didn't support this App. I love listening music with a DAC, Mojo Chord. It worked good in my new Oneplus until the Android updated to 7.0. Since then, every time I listen music with USB Audio Player Pro, the App cut off after a few minutes, between 5 and 12 minutes. It is annoying. I sent an email to the App and they told me there are some issues with the Oneplus and the new Android. They suggested me to write down it here.
    Does anybody have this issue? Any advice?
    I am thinking of go back to Android 6, is that possible.
  4. TrumpetMike Eclair Jan 29, 2017
    TrumpetMike, Jan 29, 2017 :
    how can i delete google acc?
  5. SwapnilMakne Cupcake Jan 31, 2017
    SwapnilMakne, Jan 31, 2017 :
    Yesterday i updated my one plus 3 to nougat and it started to give me problems like:
    1) Heating - It heats a lot (without any gaming)
    2) Battery - It is draining at very fast rate.
    3) Lagging - Even while switching from settings to home screen, it takes time.
    From previous posts, i came to know the same problems were there from 2nd Jan. For now, Is there any work around for these problems?
  6. F_Pawamana_Muranal_lYDp Cupcake Jan 31, 2017
  7. kalpesh6331 Gingerbread Jan 31, 2017
    kalpesh6331, Jan 31, 2017 :
    Those of you who are facing lags still
    cache clean
    factory reset
    wipe data as well, remove everything from your phone
  8. kalpesh6331 Gingerbread Jan 31, 2017
    Hold power + volume down
  9. kalpesh6331 Gingerbread Jan 31, 2017
    cache clean
    factory reset
    Make sure you back up your data before cleaning
  10. kalpesh6331 Gingerbread Jan 31, 2017
    I do use nova launcher, and I don't have any lag
    Try the steps mentioned in the reply above
  11. kalpesh6331 Gingerbread Jan 31, 2017
    If you are talking about 4.0.2, the update is pretty much stable
    You just have to factory reset your phone once after the update
  12. kalpesh6331 Gingerbread Jan 31, 2017
    Had similar problem, factory reset helped me!
  13. SwapnilMakne Cupcake Jan 31, 2017
    Go to settings- Gestures and enable three-finger screenshot. Then move ur 3 fingers from bottom to top.
    It will give u screenshot.
  14. G_tinku_kushwah_Ervg Eclair Jan 31, 2017
  15. SwapnilMakne Cupcake Jan 31, 2017
    For most of the users, it didn't work. I tried other things from google. If they fail, I'll try ur mentioned solution.
  16. kalpesh6331 Gingerbread Jan 31, 2017
    I see its working for lot of us, worked for me too
    Most of the problems are getting resolved by a factory reset
    All the best :)
  17. Komal gola Cupcake Jan 31, 2017
    Komal gola, Jan 31, 2017 :
    Ya my WiFi range also gt improved after it
    joebass96 likes this.
  18. Zh_kilat Android Q Jan 31, 2017
  19. vaibhav56790 Cupcake Feb 1, 2017
    vaibhav56790, Feb 1, 2017 :
    mine experience on nougat has been good, i didn't use marshallow since when i brought it the update was available through vpn and did factory reset later after nougat install, camera quality is big letdown in lowlight for me personally comparing to nexus 6p my phone before. performance is solid good. the one plus launcher sucks as any other pre-installed launcher. the dpi setting is let down too since it should have minmium size display to amax it goes to is 454 dpi (you can change in developer setting to 514 that best setting if you like small size. ) ram management keep 20 to 22 apps which is fine by me all are apps only. fingerprint sensor it fast but you get more accurate result i had to registered my left & right thumb twice or i won't recognise my thumb if i touch different position. so i wish they somehow update the process of taking a print of the finger impression so i can manage to registered my thumb in all different position.
  20. vaibhav56790 Cupcake Feb 1, 2017
    bro i'm running cm14.1 on rn3 and performance does take a hit after a while so don't judge cm14.1 with nitrogen OS both are different.
