2
Android 8 issue in Bluetooth
  1. J1511744865789
    Cupcake Nov 27, 2017
    J1511744865789 , Nov 27, 2017 :
    After Android 8 / Oxygen 5 update my Bluetooth stopped functioning. it was working perfectly before the update. Anyone facing the same problem????
    jean-guy and aivir like this.
  2. Craigusus
    Eclair Nov 27, 2017
  3. Vaibhav_Chaturvedi
  4. B1511763786085
  5. Marty_Blore
    Marty_Blore , Nov 27, 2017 :
    Yes - same here. Bluetooth crashes and requires phone reboot. Typically fails a few mins again.
  6. fdebriey
    fdebriey , Nov 27, 2017 :
    I have a OnePlus 3 upgarded yesterday to Android O. In my case bluetooth "works" but:
    1. Bluetooth instability : regular interruptions of music of 0.2 sec or so...
    2. Via bluetooth : max sound level lower than before.
    I need to use the touch controls of the wireless headspeaker sony wh-1000xm2 to increase to max
  7. david salcedo
    david salcedo , Nov 27, 2017 :
    Unfortunately I have the same problem the phone now does not link to other bluetooth devices that I have at home altaboces etc ... Please a quick solution and already ... I do not understand how these things are not tested before supplying them to the users ..
    A solution .. Thanks
  8. TeMpL
    Gingerbread Nov 27, 2017
    TeMpL , Nov 27, 2017 :
    Same problem.. Bt death agin few seconds after reboot.. UNUSABLE.. Hav to reboot phone for 10 times a day..
  9. Craigusus
    Eclair Nov 27, 2017
    Craigusus , Nov 27, 2017 :
    Apparently, OnePlus are aware of the issue and the ROM team are working on it now. Just had a live chat with them.
    They will make an announcement when they appear to have a fix for it. Wouldn't hold your breath...
    freelancer1988 likes this.
  10. Nuvolacielo
    Cupcake Nov 28, 2017
  11. freelancer1988
    Gingerbread Nov 30, 2017
    freelancer1988 , Nov 30, 2017 :
    Same issues as well. Bluetooth just cuts out after a second or so. It might reconnect... Or it might not. Depends on the device. Worked fine before the "upgrade". :laughing:
  12. Craigusus
    Eclair Dec 20, 2017
    Craigusus , Dec 20, 2017 :
    Just had an email from OnePlus after sending them some logs. (after following some poorly written and incorrect instructions...) Apparently, they want my phone in for repair ?! Hahaha, nope, not happening!
    They have a HUGE bug in their update. That they seemingly do not want to fix themselves.
    I have factory restored my phone, twice, and it now seems to be working fine. *touch wood*
    I would suggest, unfortunately, to factory restore your phones and start from scratch. I manually backed up my files, photos, videos etc. Then wiped and restored.
    Good luck!
    G_Joel_Teixeira_Qtph likes this.
  13. G_Joel_Teixeira_Qtph
    Cupcake Dec 20, 2017
    G_Joel_Teixeira_Qtph , Dec 20, 2017 :
    I will wait for the 8.1 update, if it does not solve the issue I will reset the phone. However, the other day I changed something in dev options about Bluetooth... I did not have the issue again...
    Craigusus likes this.
  14. G_Joel_Teixeira_Qtph
  15. Craigusus
    Eclair Dec 20, 2017
    Glad you seem to have sorted the issue. BUT, the majority of users should NOT have to mess with settings/options in Developer Options to fix issues OnePlus have created.
  16. kodish.OP5
    Cupcake Jan 9, 2018
    kodish.OP5 , Jan 9, 2018 :
    Same issue in my OP5 since updating to Oreo.
    I can link my phone to my car by bluetooth, but it doesn't reconnect automatically.
    I totally refuse to restart or downgrade the phone. OP should fix that ASAP.
  17. Craigusus
    Eclair Jan 9, 2018
    Craigusus , Jan 9, 2018 :
    Head. Brick wall. Start banging.
  18. G_Joel_Teixeira_Qtph
    Cupcake Jan 9, 2018
    G_Joel_Teixeira_Qtph , Jan 9, 2018 :
    Update of my situation :
    Op3 A3003_16_171227
    ... Changing the audio codec didn't solve the issue... I received an update yesterday with the security patch of December... Looks like the issue is gone... As expected
  19. centoo
    Froyo Jan 9, 2018
    centoo , Jan 9, 2018 :
    OnePlus 5
    After Oreo update, bluetooth keeps disconnecting every 5 secondes while playing music in the car
    Downgrade to nougat, everything works fine
    I wish there will be a fix soon
    I think it's related to AVRCP. (Version 1.3 in Nougat, 1.4 in Oreo)
  20. kodish.OP5
    Cupcake Jan 9, 2018
    That doesn't work, at least in my case :(
