207
Android 9 Community Beta 2 for OnePlus 3/3T
  1. abhi2411
    Gingerbread May 6, 2019
    abhi2411 , May 6, 2019 :
    what is this going on ? enough is enough. we are being fooled by OnePlus.
  2. abhi2411
    after so much delay I don't think OnePlus 5 and 6 owners should expect 3 android version updates on their phones as OnePlus will not be willing to do. they are doing for OnePlus 3 because in haste they promised. I don't think they will ever do it for future models. they are struggling to be honest.
  3. ghostofcain
    Marshmallow May 6, 2019
    ghostofcain , May 6, 2019 :
    Can't your mate on the dev team fill you in?
    But basically you patch the bugs and then push another beta to ensure the patches haven't caused new bugs, then hopefully progress to a stable build.
  4. abhi2411
    so is OnePlus sleeping from past 1 year. for god's sake atleast give security patch if not a pie update.
  5. abhi2411
    OnePlus is struggling- tbh. this delay will cause OnePlus more harm than good. yes they will release pie update but the whole world will get to know that to upgrade a os version they took one full year. questions will be raised on the company for such a long delay.
  6. Sadra_Imam
    Sadra_Imam , May 6, 2019 :
    I really don't care about Android 9 and It's been more than a year I'm waiting for that app data backup support for OnePlus Switch...
    I really need that app data backup and It's safe to say that it won't happen.
  7. abhi2411
    from giving 8.1 then changing the decision to give pie update shows the company has no vision , no planning for its devices. same sort of thing they did with OnePlus 2. first they told they will give nougat update , then they told they won't.
    MarkAle and girishp like this.
  8. ghostofcain
    A pie update was given today, in this very thread.
    The OP2 update was cancelled due to the lack of manufacturer chipset support, the P update continues to be developed. Unless your contact on the dev teams has indicated something different?
  9. abhi2411
    then why they made announcement if they cancelled it ?? it shows thay take decisions hastly just to make headlines. same type of hasty decision they took for op3 camera which has a hump which has created problems for many custumers.
    girishp likes this.
  10. xythiii
    Ice Cream Sandwich May 6, 2019
    iamrikayan likes this.
  11. ghostofcain
    Really? Where these customers not aware of the hump when they purchased the device, or did they purchase in haste without looking at the device? The hump certainly never bothered me.
  12. abhi2411
    you need knowledge my friend. go through this link https://www.google.com/amp/s/www.ib...-have-crooked-camera-bump-issue-2512854?amp=1
    do you know what is pressure ?? the whole 155 grms pressure is going on that camera hump. ensuring one day that the glass will break.
    rameez0307 likes this.
  13. 翩然而至你早已不在
    Cupcake May 6, 2019
  14. kuldip_prajapati
    Donut May 7, 2019
    kuldip_prajapati , May 7, 2019 :
    my recent panel has the same issue as same as the first community beta update..
    they are same as oreo.
    how to fix this..??
  15. sammerasker
    Ice Cream Sandwich May 7, 2019
    sammerasker , May 7, 2019 :
    many compnaies made an announcement for the update...including Sony for the Z3 , and they actually released a Developers build , then Qualcom dropped support for the chip, so they canceled the update, OnePlus wasn't the ONLY company to do this.
    Try o use google.
    also the 3/3T have an almost complete update (now on beta) as you can see, whole different story...
    you don't like it, don't buy another device from them, easy.
    the same way you updated to the 1st one...also it's mentioned in the 1st post.
    clear the launcher data and cache...and if you installed the launcher from apkmirror, uninstall it 1st.
    the reason you have the issue is because you didn't do a clean flash (on the 1st build).
    Ranjithsmart and Android450 like this.
  16. PARTHI_SaNjay
    Honeycomb May 7, 2019
    PARTHI_SaNjay , May 7, 2019 :
    Im in community beta build1..is it safe to update to Community beta build2? Is it occurs data loss?
  17. theshinybeast
    Marshmallow May 7, 2019
    theshinybeast , May 7, 2019 :
    Yes I agree you do need knowledge because you are bereft of any knowledge from what I've read in your posts. Gibberish is all I've seen and this hump nonsense just moaning about nothing is a prime example. Flash the update and stop crying please.
  18. sammerasker
    just download and from the system update do a local upgrade, you shouldn't loose data, also go to recovery after the update and clear cache (only cache)...again no you shouldn't loose data.
    #38
  19. Daniel Hee
    Gingerbread May 7, 2019
    Daniel Hee , May 7, 2019 :
    dude, instead of complaining about things that don't make sense if you are a decent human being and just think about how a company operates, why don't you go get a life. it's just a phone... a 3 year one in fact. is there nothing better in your life that is worth your attention?.... nothing?
    #39
  20. U1515516364983
    Cupcake May 7, 2019
