207
Android 9 Community Beta 2 for OnePlus 3/3T
  1. ghostofcain
    Marshmallow May 9, 2019
    ghostofcain , May 9, 2019 :
    There never was an official 8.1 build for OP3(T), what exactly are you running?
    Auristic likes this.
  2. gaurav27jul
    Gingerbread May 9, 2019
    gaurav27jul , May 9, 2019 :
    Hi, facing a bug in 3t. Whenever I press power button to see lock screen. It shows tinted colors. I have changed wallpapers but still it's showing green transparent layer on wall paper.
  3. F_Prashant_Karmacharya_U
    Ice Cream Sandwich May 9, 2019
    F_Prashant_Karmacharya_U , May 9, 2019 :
    If you mean stable then yes!
  4. F_Prashant_Karmacharya_U
    yep, same happened to me as well..
    Try using darker wallpapers mainly blue or black.
    gaurav27jul likes this.
  5. devssks
    Froyo May 9, 2019
    devssks , May 9, 2019 :
    I have to report a very peculiar bug, was wondering if anyone else having same issue. whenever I connect phone to computer or laptop for file transfer, phone's internal storage do pop up on computer but the folder is empty.
    I have to remove it and connect several time before internal storage starts to show content of the phone.
    had this issue in C. beta 1 as well.
    papakyriazis likes this.
  6. G_Олег_Сербин_
    Cupcake May 9, 2019
    G_Олег_Сербин_ , May 9, 2019 :
    Thanks for what you're doing to users Oneplus 3t. Using beta2 and waiting official update. Using this gadget 3-rd year and will update smartphone only prodused company Oneplus. Thanks for work!!!
  7. Yash Narain
  8. Neelavar Sumanth
    Neelavar Sumanth , May 9, 2019 :
    you need to select MTP or File transfer after connecting the phone to Laptop or PC .
    if that is not your Problem . is your Phone charging Fine ?
    maybe a Hardware issue , if so ,Reach out to one of the service centres and get it diagnosed.
    ghostofcain likes this.
  9. ghostofcain
    Not in an OOS thread, no
    gazz1701 likes this.
  10. G_Ami_Rude_vJJv
    Cupcake May 9, 2019
  11. ghostofcain
    No, but then neither does a properly installed CB1.
  12. devssks
    Froyo May 9, 2019
    that's not the problem. phone is charging fine, bit slower than usual since pie beta, I read lot of people commenting about it so nothing significant.
    I started having the file transfer issue after install beta pie, I know.. b/c I use usb file transfer on this device quite often, so I suppose it's a software issue.
  13. G_Ami_Rude_vJJv
    Cupcake May 9, 2019
    G_Ami_Rude_vJJv , May 9, 2019 :
    i downloaded cb1 on phone. installed it from recovery mode. rebooted phone. cleared cache. rebooted again.
    what did i miss? for "properly installed"
  14. Neelavar Sumanth
    Did you try doing a Clean install?
    you have this issue from when?
    and have you Shared the feedback through appropriate forums?
  15. E1509764669189
    Cupcake May 9, 2019
    E1509764669189 , May 9, 2019 :
    I have downloaded android 9 version for op3 but oxygen is is only 9.0 am having ..how to upgrade it to 9.0.1?
  16. Neelavar Sumanth
    nothing wrong , You're on CB1 now ?
    we have the CB 2 now . try that on if you could
    G_Ami_Rude_vJJv likes this.
  17. G_Nitin_Mathur_GbWA
    Cupcake May 9, 2019
  18. Neelavar Sumanth
    after clicking the Download link . Press the 3 dot menu on Right top corner and click Open in Browser . Download will Start in a few seconds accordingly to your Data Speeds
  19. Neelavar Sumanth
    Its Android 9.0 Pie in Generic Terms
    and Oxygen OS versions may have different numbering . but
    Oxygen OS 9.0.1 is Based on Android Pie 9.0
    You can Install CB 2 If you want the latest Pie Beta . or you can wait for Stable Pie ( no ETA's yet)
  20. E1509764669189
    Cupcake May 9, 2019
    now I have downloaded 1.5gb of storage of android pie ...but oxygen os is 9.0 only... it should be 9.0.1 to fix the bug and microphone issues
