207
Android 9 Community Beta 2 for OnePlus 3/3T
  1. ghostofcain
    Marshmallow May 12, 2019
    ghostofcain , May 12, 2019 :
    And are you the arbiter of that, have YOU collated the bug reports etc?
    Auristic likes this.
  2. Mac_Blacness
    Eclair May 12, 2019
    Mac_Blacness , May 12, 2019 :
    No I'm not and neither are you , but why push out 5 betas just to get to a stable build, I advise they take their time and put out a stable build.
  3. Rizwan.Ge
    Cupcake May 12, 2019
    Rizwan.Ge , May 12, 2019 :
    How to install in unlocked bootloader device Sir please tell me the solution Thanks
  4. AnuGeorge
    Gingerbread May 12, 2019
    AnuGeorge , May 12, 2019 :
    Iam already great full with Oreo but pie too much delayed. ok then time will reveal stable ver will wait.
  5. Mac_Blacness
    Eclair May 12, 2019
    Just do a local update . You won't lose data
  6. Silvio_Pinto
    Silvio_Pinto , May 12, 2019 :
    Guys I'm experiencing battery drain after the installation of this CB2. Anyone has the same problem?
  7. mikica023
    Honeycomb May 12, 2019
    mikica023 , May 12, 2019 :
    Only problem for me it's mobile network standby CB1 and on CB2. Hard reset after installation CB1 from 5.0.8, and after CB1 to CB2.
  8. noisy.lightning
    Eclair May 12, 2019
    noisy.lightning , May 12, 2019 :
    I also have have higher than usual standby cell drain. Was never this bad on previous builds.
  9. Silvio_Pinto
    For me the situation was normal on CB1, the issue presented on CB2
  10. Jahid211
    Donut May 12, 2019
    Jahid211 , May 12, 2019 :
    Guys you can flash Community beta 2 without any hesitation. cause it's super smooth and no bugs. Consider this as Stable. But there is a minor problem with google play store. Apps keep showing downloading. Is that only happens to me or its universal . please let me know
  11. Jahid211
    Donut May 12, 2019
    it works. I'm using magisk 19 in this update
  12. Cervantes
    Lollipop Moderator May 12, 2019
    Cervantes , May 12, 2019 :
    Hi
    The update or beta thread is a thread of questions and/or commentary
    Please, read the first post
    Thread merged
    sammerasker and Jahid211 like this.
  13. sammerasker
    Ice Cream Sandwich May 13, 2019
    sammerasker , May 13, 2019 :
    Because how would they know it's stable? No matter how good the closed tester are, they can't represent the general users, real life testing is good.
  14. gaurav27jul
    Gingerbread May 13, 2019
    gaurav27jul , May 13, 2019 :
    U didn't configured game mode properly. There's a option for turn on buttons. U will get notifications depends on how you configured.
  15. gaurav27jul
    Only with you.. [e]1f609[/e] You are right.. It has minor bugs.. But we can use it without any doubt.
  16. G1531941326404
    Cupcake May 13, 2019
  17. Haidar Ali
    Haidar Ali , May 13, 2019 :
    some times call not disconnected when i press the call disconnect button then minimize to status bar.
  18. Yug Desai
    Yug Desai , May 13, 2019 :
    lol. i have been using same configuration for 2 years all of sudden notification starts to pop up.
  19. gaurav27jul
    Lolita... How do i knw you are using it properly... [e]1f609[/e] [e]1f609[/e]
  20. Yug Desai
