207
Android 9 Community Beta 2 for OnePlus 3/3T
  1. Raj_16
    Cupcake May 13, 2019
    f00tbaLL likes this.
  2. javimgmt
  3. abhi2411
    Gingerbread May 13, 2019
    abhi2411 , May 13, 2019 :
    i mean they released It and ppl didn't felt that it's has taken them too long . but Oneplus 3 users are getting the feel that the update has been taking lot of time to release.
  4. ghostofcain
    Marshmallow May 13, 2019
    ghostofcain , May 13, 2019 :
    People might not have felt it took too long, but they complained in droves that it felt rushed, was overly bug ridden .
    Auristic likes this.
  5. abhi2411
    so are people facing problems ??
  6. ravidesai47
    Honeycomb May 13, 2019
    ravidesai47 , May 13, 2019 :
    OnePlus Camera app is missing so many features which were present in Oreo. Specially manual mode...
  7. Rajat Rangdal
    Donut May 13, 2019
    Rajat Rangdal , May 13, 2019 :
    I'm on community update 1,if I install community update 2, will the data get erased?
  8. G1551551673573
    G1551551673573 , May 13, 2019 :
    i did local upgrade ! data is not erased so no
  9. TeMpL
    TeMpL , May 13, 2019 :
    lol... it unusable slow..
    try linage os build its..at least usable, and gps work reliable..
    pie 3t build.. is much slower than oreo..
  10. Mahendra Tripathi
    Eclair May 13, 2019
  11. Raj_16
  12. gazz1701
    Jelly Bean May 13, 2019
    gazz1701 , May 13, 2019 :
    Disagree - not run any timings, but subjectively in daily use performance is comparable to 5.0.8 Oreo on my 3T... not observing any slowness or un-usabiliry.
    AnuGeorge, LoeKis and keithgpowell like this.
  13. gazz1701
    Not true - if you look above the word Photo you should see small arrow, use to slide up buttons for options including Pro Mode where all the manual settings are...
    Soild_UK and ravidesai47 like this.
  14. ravidesai47
    Thanks for the info...
    gazz1701 likes this.
  15. keithgpowell
    Ice Cream Sandwich May 13, 2019
    keithgpowell , May 13, 2019 :
    ravidesai47
    OnePlus Camera app is missing so many features which were present in Oreo. Specially manual mode...​
    Disagree.
    It's called "Pro Mode".
    Tap or swipe up the "arrow".
    version 3.0.37?
  16. ravidesai47
    I checked it...
    Its there...
    (y)
  17. jcunha20
    Donut May 13, 2019
    jcunha20 , May 13, 2019 :
    I found a possible bug... anyone have problems with AR+ like google AR stickers? at least for me when open the gcam with the playground option the app crash everytime... I found it playing Pokémon Go.
  18. N1544287666635
    N1544287666635 , May 13, 2019 :
    after updating to android pie some issues which i notice
    1. on status bar bluetooth awake icon is not visible
    2. ar core is not working
    3. speaker volume low problem
    4. battery drain fast and heat up
    5. little speed issue
    6. sim card number edit
    rmkimathi likes this.
  19. N1544287666635
    no
  20. ghostofcain
    I thought gCam was only officially supported on pixel phones?
