207
Android 9 Community Beta 2 for OnePlus 3/3T
  1. alexfromgermany
    Froyo May 14, 2019
    alexfromgermany , May 14, 2019 :
    When will the finished update finally arrive? why the **** takes so long. fucks me off [e]1f620[/e][e]1f620[/e][e]1f620[/e][e]1f620[/e][e]1f620[/e]
  2. PrashantKarma
    Ice Cream Sandwich May 14, 2019
    PrashantKarma , May 14, 2019 :
    i think you select deep clear option instead of normal clear under recent app management.
  3. akst
    Gingerbread May 14, 2019
    akst , May 14, 2019 :
    Battery optimization settings resets after reboot. Is this normal?
  4. Neddard
    Lollipop May 14, 2019
    Neddard , May 14, 2019 :
    Such eloquence :rolleyes:
    gazz1701 and RoverX like this.
  5. Ujjwal85
  6. Tejas60
    Cupcake May 14, 2019
    G_Alexander_P._ZyZw likes this.
  7. Neddard
    No one can tell you, and OP doesn't publish ETAs.
    ghostofcain and Tejas60 like this.
  8. Tejas60
  9. Neddard
    No one can say, even approximately.
    OP will release it when they deem it ready.
    gazz1701 and ghostofcain like this.
  10. sachin j
    sachin j , May 14, 2019 :
    sounds not stopped after closing sounds related apps restart only one option
  11. Daniel Muresan RO
    Eclair May 14, 2019
    Daniel Muresan RO , May 14, 2019 :
    yea same thing happens to me but i reported it so we'll see
  12. B1557406366378
  13. Soild_UK
    Froyo May 14, 2019
    Soild_UK , May 14, 2019 :
    I wonder if the missing notification / Shows up when the app is open is related to the battery saving mode (and data limits as a result)?
    gazz1701 likes this.
  14. ssaikiran92
    Honeycomb May 14, 2019
    ssaikiran92 , May 14, 2019 :
    Just remove the battery optimization for the app which you are facing the issue. It would resolve.
  15. Daniel Muresan RO
    Eclair May 14, 2019
  16. R1557492047929
    R1557492047929 , May 14, 2019 :
    Wow. It's working now. Let me see if it works going forward.
    Thanks times for such suggestion mate..[e]1f603[/e]
  17. PrashantKarma
    anytime mate [e]1f44d[/e]
  18. gazz1701
    Jelly Bean May 14, 2019
    gazz1701 , May 14, 2019 :
    Yes - I had issues with Garmin Connect (that does notifications to my Garmin watch) until turned off battery optimisation for the app... with it on, only worked if manually opened app then all missed notifications came at once.
  19. saad__khalid
  20. emeron
    Eclair May 14, 2019
    emeron , May 14, 2019 :
    I did and still having issues with notifications. I'll report it directly as well.
    Daniel Muresan RO likes this.
