207
Android 9 Community Beta 2 for OnePlus 3/3T
  1. gazz1701
    Jelly Bean May 15, 2019
    gazz1701 , May 15, 2019 :
    No, it's you that is not getting me... we're saying the same thing, we actually agree for once...
  2. abhi2411
    Gingerbread May 15, 2019
    abhi2411 , May 15, 2019 :
    no bro. see, OnePlus 5 users will demand for Q (and they have every right) Because Oneplus 3 has got 3 major updates now being a 3 year old device whereas OnePlus 5 is going to be a 2 yr old device in few months. so they should get a Q update as they promised they will give android support for 2 years. OnePlus 3 is that lucky device which will get an update when the phone is getting 3 yrs old. and I don't know why users are demanding Q for Oneplus 3 now. terrible.
  3. B.yashaswi
    Ice Cream Sandwich May 15, 2019
    B.yashaswi , May 15, 2019 :
    Phone does not dash charge sometimes and also while writing this same problem started happening so is anyone having this issue.
  4. thefraggle
    Eclair May 15, 2019
    thefraggle , May 15, 2019 :
    I did a clean install of Beta 1 and th n updated to Beta 2.
    all good so far, except the phone is really getting hot while charging...
  5. santhoshk09
    Donut May 15, 2019
  6. devssks
    Froyo May 15, 2019
    devssks , May 15, 2019 :
    how old is your charging cable ? More often than not, fast charge related issues are regarding charging cable than anything else. try another different OnePlus charger if you know someone who has it,or change your cable, if it works good enough otherwise it could be software/ hardware issue.
    Run OnePlus care full diagnostic to check of port is working fine or not.
  7. B.yashaswi
    Now it is working fine, phone was in a Same position then heard the sound of rapid charging again everything back to normal.
  8. Paschfire
    KitKat May 15, 2019
    Paschfire , May 15, 2019 :
    Please use the official Community Beta thread for reporting, or discussions about, issues, features and options related to the community beta.
    Don't create unnecessary redundant threads.
    Instructions on how to report bugs/issues and other FAQ can be found within the pinned comments atop that thread.
    All beta related comments/questions should be posted within the Community Beta thread only, here;
    https://forums.oneplus.com/threads/taste-of-pie-android-9-community-beta-for-oneplus-3-3t.1015981/
    Also using the Community Beta 2 thread for the most recent CB2 Pie 9 update, here;
    https://forums.oneplus.com/threads/android-9-community-beta-2-for-oneplus-3-3t.1028413/
    And/Or, submit a proper detailed report about such issues or concerns, here;
  9. Z1517060737053
    Cupcake May 15, 2019
    CptnAbhi and Arjun Muchhadiya like this.
  10. tezun23
    Eclair May 15, 2019
    tezun23 , May 15, 2019 :
    A few more minutes...
  11. Z1517060737053
  12. Ddemers
    Ddemers , May 15, 2019 :
    Check for lint in your charger port on the phone, the same thing happened to me and it was only that! Better than getting a new charger to test it...
  13. B.yashaswi
    Everything is fine with the charger ,I have to test it should keep the other charger with me and should verify if at all it happens again then can decide what is the actual cause of problem.
  14. Aakash360
    Honeycomb May 15, 2019
    Aakash360 , May 15, 2019 :
    There are bugs in this bulid :-
    1.) When a call is incoming, the ringtone keeps on playing and shows nothing on the mobile screen except the homescreen...no dialer is visible for 5secs.
    2.) While performing outgoing calls and pressing the number to be called to.,the screen doesn't come right away most of the times i have to perform the calling action twice or more.
    3.) While on call I can't pull the status bar down in just one go..it glitches multiple time until i hold it and slowly pull it down.
    These are the main irritating bugs, I hope you guys fix it in the next build.
  15. rameez0307
    rameez0307 , May 15, 2019 :
    official update release date 31/12/2019.. still daydreaming about the update..
  16. Z1517060737053
    Z1517060737053 , May 15, 2019 :
    ooooh my god....
  17. G_lovepreet_muker_ipzC
    Eclair May 15, 2019
  18. Transcendant
    Ankitbhat12345 likes this.
  19. Ankitbhat12345
  20. rameez0307
    official update release date 31/12/2019 for apple pie (3/3T) [technically speaking this update is basically to ruin a perfect 3/3T, just to force them to buy a new device, a strategy no one speaks, its a guarantee you will see hell break loose once you get this update].. official android Q (qulcha) update release date is 1/1/2050.. still daydreaming about the update..
