207
Android 9 Community Beta 2 for OnePlus 3/3T
  1. dasche
    Gingerbread May 16, 2019
    dasche , May 16, 2019 :
    Why people are insulting people and oneplus team members? Don't tell me to read previous posts.
    mk92 likes this.
  2. gazz1701
    Jelly Bean May 16, 2019
    gazz1701 , May 16, 2019 :
    They're childish... simple reason You sure you've been here before, it's not new...[e]1f609[/e]
    mk92 and ghostofcain like this.
  3. dasche
    gazz1701 likes this.
  4. George+One
    Cupcake May 16, 2019
    George+One , May 16, 2019 :
    I don't know why my boot loader is unlocked but it's so complicated to lock it because it wipes the device. I don't have enough space on the phone to perform a backup and there is no option to backup directly to PC. I'll have to wait for the stable release. Hopefully that will be compatible with unlocked boot loaders.
  5. Kx1707
    Gingerbread May 17, 2019
  6. Salman Saud
    Donut May 17, 2019
    9390969044 likes this.
  7. Konamy
    Froyo May 17, 2019
  8. UdayKiran Ramisetty
    Donut May 17, 2019
    UdayKiran Ramisetty , May 17, 2019 :
    on Which Rom you are on right now? Even my bootloader is unlocked but i have installed latest community build of pie..
    steps:
    1. Install latest stable build (oreo, Oxygen OS 5.0.8) on your device ( bootloader unlocked Devices)
    2. Reset your phone after installation of latest
    3. Now download latest community build and copy in root folder of your device.
    4. Install it using 'Local Upgrade' option in system update.
    done!!
  9. Maksym Rybak2017
    Cupcake May 17, 2019
    Maksym Rybak2017 , May 17, 2019 :
    yes. it is help . thanks
  10. Cosmos_NT
    Jelly Bean May 17, 2019
    Cosmos_NT , May 17, 2019 :
    @ghostofcain are you facing issues in Download icon on status bar ?
    When I am updating apps or downloading something from chrome, the icon of download isn't appearing in status bar unless I pull it down, also it seems it isn't shown on Liftup display. Before I report I wanted to know that if it is my device's fault or is it general.
  11. noisy.lightning
    Eclair May 17, 2019
    noisy.lightning , May 17, 2019 :
    Android pie now. Will automatically hide notifications you regularly dismiss. You can enable them again in settings under "apps and notifications"
  12. Swp1996
  13. Cosmos_NT
    I know that bro, problem is it randomly appears and again disappears that's the problem if it is only device limited or general
    PS : I already had enabled all permission for Play store and Download Manager so question remains the same. It does show icon after downloading is completed but not while is in process, this in process icon pops randomly and that's bothering.
  14. Gdsingh94
    Honeycomb May 17, 2019
    Gdsingh94 , May 17, 2019 :
    change the notification settings of downloads apps... and it will show up
    Cosmos_NT likes this.
  15. daviddt
    Eclair May 17, 2019
    daviddt , May 17, 2019 :
    In the Do Not Disturb mode, when you call, the curtain does not drop down with a swipe to reject a call 2) When selecting a large font in the phone book, the name is HUGE FONT 3) Inconvenient switching between applications from left to right from top to bottom is much better
  16. SoniaB
    Nougat Senior Moderator May 17, 2019
    SoniaB , May 17, 2019 :
    Thread merged. Please ensure you follow forum rules and post in the existing thread. In this case here or report bugs via the bug reporting platform.
  17. PAPZI1957
    PAPZI1957 , May 17, 2019 :
    Is there a sound processor application that can be used to change the Bluetooth and USB headset settings?
    Audio Tuner does not work in any case!
  18. jaysolanki49
    Donut May 17, 2019
    jaysolanki49 , May 17, 2019 :
    Hey guys, any help would be great for the below problem that i am facing abruptly:
    Home button and recent apps not working with onscreen or physical buttons..only back button working.
    Oneplus launcher shows blank home screen..no icons or widgets visible.
  19. AnuGeorge
    AnuGeorge , May 17, 2019 :
    I did not installed pie beta 1&2 yet so I know it's like trial checking for bugs and all of them eager and tasted bugs not pie. It's better to stick with stable Oreo right not and wait till pie stable release it's the best way to keep device stable and healthy.
  20. madassuk
    Eclair May 17, 2019
    madassuk , May 17, 2019 :
    Very close now. Cannot believe how much this has improved the phone.
    Going to be the hardest thing to relegate this in a few days for the pro.
    Almost tempted to cancel and hold out for next one.
    EDIT. deleted the fingerprint unlock issue. once recalibrated it works fine.
