207
Android 9 Community Beta 2 for OnePlus 3/3T
  1. its_cn
    Cupcake May 30, 2019
  2. gaurav27jul
    Gingerbread May 30, 2019
    gaurav27jul , May 30, 2019 :
    Stable update already rolled out... Hold on for sometime
    its_cn likes this.
  3. G_Nitin_Mathur_GbWA
    Cupcake May 31, 2019
  4. ghostofcain
    Marshmallow May 31, 2019
    ghostofcain , May 31, 2019 :
    Try updating to the stable build, btw immediately after updating ( first 3 - 4 battery cycles) heating especially during idle periods is to be expected.
  5. G_Nitin_Mathur_GbWA
    Cupcake Jun 1, 2019
    G_Nitin_Mathur_GbWA , Jun 1, 2019 :
    Didn't understand, what are you suggesting.
  6. G_Shaun_Benny_agrv
    Froyo Jun 4, 2019
  7. ghostofcain
    Marshmallow Jun 4, 2019
    ghostofcain , Jun 4, 2019 :
    1. After updating increased CPU usage will cause a degree of heating and battery drain, this usually resolves after a couple of charge cycles.
    2. You have updated to an older community build, why not try the stable release instead, issues with this build CB 2 will never be fixed.
  8. VBH
    Froyo Jul 7, 2019
    VBH , Jul 7, 2019 :
    I am trying to install this Community Beta 2 on my Open Beta 39 installed Oneplus 3. I select the zip file from the recovery and it shows around 10% progress bar for around 5 seconds and then go backs to the file selection screen. I even tried adb sideloading, which will show the progress bar on the mobile at the same position, but the adb shows loading till 100% and then the mobile will show the message that the sideloading failed.
    Is this a know issue and is there any solution for this?
  9. G_Livingston_Stanley_elw
    Froyo Jul 7, 2019
    G_Livingston_Stanley_elw , Jul 7, 2019 :
    try to fomat the entire internal storage and then copy the installation file and install it.
