Android Auto bug after Oxygen OS 11.0.6.6.IN11AA? via OnePlus 8 Pro
  1. N1591938079182 , via OnePlus 8 Pro , Jun 10, 2021 :
    After this update android auto has been extremely inconsistent connecting and will randomly require me to unlock my phone and go through the android auto setup. It never use to require manual intervention after the first setup was completed. I've tried everything to fix it.
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert Jun 10, 2021
    Dresa91 , Jun 10, 2021 :
    What is everything?
    can you please reinstall Android Auto?
    Arjun_Choudhry likes this.
  3. N1591938079182 , via OnePlus 8 Pro , Jun 10, 2021 :
    I've reset all network and Bluetooth connections, deleted cache and uninstalled/reinstalled Android Auto, tried different cable's, installed 3 different versions of the Ford Sync System Software, Even tried a Samsung phone. The issue persists. I didn't test another phone before opening this thread. So the fact that it is happening on another phone eliminates the possibility of it being a OnePlus system software bug. It must be a recent android auto update that broke this. I can't find a solution or definitive answer.
  4. Dresa91
    Are you using the latest version of it?
    Can you please compare it with the version uploaded on apkmirror.com?
    Did you contact Google? Google is the dev of Android Auto
  5. #5
  6. Dresa91
    Please download the latest version from apkmirror - make sure you are downloading the correct version
  7. Dresa91
  8. #8
  9. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert Jun 11, 2021
    Dresa91 , Jun 11, 2021 :
    Contact Google support
  10. #10
  11. Dresa91
    Okay, did you also make sure you are using the latest Google Play Services?
  12. #12
  13. Dresa91
    Please do it
  14. #14
  15. Dresa91
  16. #16
  17. Dresa91
  18. #18
  19. Dresa91
    Then please wait
  20. G1583718404830
    Cupcake Oct 17, 2021
    G1583718404830 , Oct 17, 2021 :
    absolutely NOTHING TO DO with the verision of Google Play. It's oneplus os11 update. Period end of story. Any one want to buy a 8 month old useless OnePlus 7 pro paperweight? Originally $600. This company OnePlus is a joke, another start up trash can with a 7 billion dollar valuation like the rest of the trash.
