Android auto connectivity issue
  1. AbhiSakhumalla
    Cupcake Aug 19, 2019
    AbhiSakhumalla , Aug 19, 2019 :
    hello
    I have been facing of connecting my OnePlus 7 to my
    Sony Audio System ( XAV AV5000 - top model from Sony at the moment )
    when connected via the cable phone and audio system recognizes and open Andriod Auto for 5-10 before the audio system freezes and disconnects and reboots again the devices connects Andriod Auto now I can use it for up to 30 seconds and then permanently disconnects and there is an error message on the audio system ' USB device not supported '
    this is a pattern keeps repeating again and again.
    I have check with different cables, same problem
    I've check with older OnePlus phones / Android devices they work perfectly Android auto works ( Phone + System )
    Problem is only with OnePlus 7 device ..
    does anybody else face this issue ?
    any solution?
    or could there be a problem with my phone ?
    thanks!
    wesleycolls likes this.
  2. wesleycolls
    Cupcake Aug 20, 2019
    wesleycolls , Aug 20, 2019 :
    I'm struggling with connecting to my car. It works once and doesn't work after that. it's quite a struggle which is not the case with iPhone.
