Android Auto Issue After Pie Update
  1. chrism380
    Ice Cream Sandwich Feb 16, 2019
    chrism380 , Feb 16, 2019 :
    Have a Ford with Sync, previously AA worked flawlessly. After update, any non Google apps are not launching. Google maps, Google music, Google podcast all work fine. When I launch Waze, black screen and freezes. Spotify or Pandora gives the error Android Auto Media, Pandora doesn't seem to be working right now.
    I uninstalled AA and reset system, no luck.
    wiped cache and reinstalled, no luck.
    Uninstalled Waze, Spotify, Pandora, Android Auto, wiped Chrome Settings. reinstalled, launched, same issue.
    If I launch Waze first on my phone, then connect USB, then select Navigate Home from AA, it opens it.
    Any ideas or is anyone else have a similar issue?
  2. patrickvas
    Cupcake Apr 8, 2019
    patrickvas , Apr 8, 2019 :
    I actually have this same issue on my 6T, figured it's relevant so I could mention it and see if anyone's come up with anything . It's sporadic because last week it was working fine .
    OOS 6T Beta 7
    Android Auto 4.1.590944-release
    Waze 4.49.1.2
    Edit: also should mention this is happening in a 2019 VW Jetta with the factory Carplay/AA radio so it doesn't appear to be manufacturer specific.
  3. Waveform Modifier
    Marshmallow Apr 8, 2019
    Waveform Modifier , Apr 8, 2019 :
    Wrong forum.
    And all beta related comment, inquires and complaints must be directed to the pinned beta thread only.
  4. patrickvas
    Cupcake Apr 8, 2019
    Felt it was worth mentioning since it's likely an AA or Waze issue and not an OOS one, but ok. Not a big deal man, you'll be fine.
    Ashenmx likes this.
  5. fazerboy0_3
    Honeycomb Apr 8, 2019
    fazerboy0_3 , Apr 8, 2019 :
    I found with my Kia I had to open each app first before plugged in to run AA Then it worked fine. Did you take the car for a service ie have Ford updated your software..
  6. mlord
    Gingerbread Apr 26, 2019
    mlord , Apr 26, 2019 :
    Android Auto failing on OnePlus phones seems to be an OxygenOS issue. Installing alternative ROMs [eg. LineageOS, CM, or (the best at present) MSM Xtended] cures the problem.
  7. Mr_Cyrox
    KitKat Apr 27, 2019
    Mr_Cyrox , Apr 27, 2019 :
    And yet people on OxygenOS find success on using Android Auto...
    Not all for some reason...
  8. X1542793413065
    Cupcake May 24, 2019
    X1542793413065 , May 24, 2019 :
    Make sure you don't have deep optimization of battery turned on, that broke AA for me with media playback
  9. mcfetti
    Eclair Jun 27, 2019
    mcfetti , Jun 27, 2019 :
    Well I've had problems since the Pie update on my Oneplus 3T, worked fine before update, Android Auto closing on first opening, on second click it works but had problems connecting to my car. I activated Developer Mode (for phone not Android Auto) and changed background processes to no more than 2 and it seems to have fixed both problems. The car connection required a few attempts at connecting but seems to work at least for a few mins. Will test more on my way home.
