3
Android Auto keeps disconnecting continuously via OnePlus 9
  1. ishanpatel3
    Donut Aug 26, 2021
    ishanpatel3 , via OnePlus 9 , Aug 26, 2021 :
    Hello there,
    I hope this message finds you all well.
    I'm not sure if can help, but for some reason when I connect my phone via usb type c to my car it just continuously connect for a split second and the disconnects.
    I have checked my cable and used different ones and still the same issue. I have also tried another phone (Samsung S20) and this connects fine to my car.
    Can anyone provide any assistance as to why I am getting this continuous connect and disconnect when using android auto?
    Thank you :)
    ipeleg, suyashbiradar and pratikg1992 like this.
  2. Swejuggalo
    OnePlus 9 Series Expert Community Expert Aug 26, 2021
  3. ishanpatel3
    Donut Aug 27, 2021
    ishanpatel3 , via OnePlus 9 , Aug 27, 2021 :
    Yeah I tried the plugging in phone before starting the car, but didn't didn't seem to work :(
    Had a look on the Google site to check all variables but still no luck :( any other ideas?
  4. Srishti Chetry01
    OnePlus Bug Hunter Staff Member Aug 31, 2021
    Srishti Chetry01 , Aug 31, 2021 :
    We understand your concern and relate to the issue you are facing and have contacted you via personal message.
    Thanks & regards,
    Srishti.
  5. giladcarmeli
    Cupcake Sep 8, 2021
    giladcarmeli , Sep 8, 2021 :
    Hello
    I have the same problem:
    connect my phone via usb type c to my car it just continuously connect for a split second and the disconnects...
    Any help ?
    Thanks, gilad
  6. suyashbiradar
    Cupcake Sep 10, 2021
    suyashbiradar , via OnePlus 9 Pro , Sep 10, 2021 :
    Me also fasing the same problem.
    For that every discount I need to change ube mode to other than no data transfer mode after few seconds again it goes to no data transfer mode and andriod auto get connected.
    Need solution for this.
    Note : I have tried with original cable of one plus.
  7. X1628591169686
    Cupcake Sep 13, 2021
    X1628591169686 , Sep 13, 2021 :
    Hi Guys
    Can I get in on this issue?
    Until last month I had a Xiaomi Mi, it worked well with Android Auto until June when it started to continually disconnect.
    Tried changing cables and changing the auxiliary unput unit on my car but to no avail.
    Still have the same issue with my new Nord hardset.
    Looking around the net, it seems that this has become a common issue, and Samsung have updated their OS to fix the issue, so it looks like there is something in Android Auto that isn't co-operating with various OS's.
    Not sure why Google keep messing around with things that work perfectly well, especially when so many car head units now rely on Android Auto for SatNav and Entertainment rather than having systems inbuilt.
    Bluetooth does not provide the functionality and also plays really quietly, even when you override the noise suppression in Developer Options.
    If there is a cure, please let me know.
    Thanks
    Kev
  8. pratikg1992
    Cupcake Sep 22, 2021
    pratikg1992 , Sep 22, 2021 :
    Hi,
    I have the same issue going on with OnePlus 9. This is very inconvenient and honestly risky because it's distracting while driving. Please share a solution to this. I have tried resetting the Network settings, device.. nothing worked.
  9. H1632369140744
    Cupcake Sep 23, 2021
    H1632369140744 , Sep 23, 2021 :
    Hi Guys,
    I am using One Plus 9 and I haven't tried the android auto function yet but I am having issues with type C connection with headphones. The headphone doesn't get recognized until I toggle the OTG storage function to ON position, but the headphones automatically gets disconnected after 10 minutes and the audio starts playing thorough the phone speaker. The phone was never idle, I tired reconnecting the headphones but its the same. I have to goto settings-> OTG storage and enable the switch back ON to recognize the headphones, but after 10 minutes it gets disconnected.. repeat!!! This is a bit frustrating, has anyone any idea about this???
    PS: same headphones works perfectly with my laptops, motoral phone, S21 Ultra, S20 Ultra, Red Magic phones... these are the ones that I tested on.. extensively.
  10. D1619093189488
    D1619093189488 , Sep 23, 2021 :
    Hi,
    Is there any Update or Solution to this Problem?
    I just got my OnePlus 9 Pro and i have the exact same Problem.
    I tried restarting my Phone.
    Connecting the Cable before Starting my Madza 3 (2019)
    Deactivated Android Auto and Updated it again.
    Deleting its Data and Cache.
    Changing the Default USB Setting to PTP or MIDI or anything available...
    I tried changing Bluetooth und Android Auto Setting.
    I had no Problems with my Old Phone (Samsung S7).
    Arragorn likes this.
  11. Arragorn
    Cupcake Sep 30, 2021
    Arragorn , Sep 30, 2021 :
    Here how you get Android Auto working in your car or truck. Go settings erase all personnel data on your cars touch screen and sorry yes you will lose all your settings but this works. Also erase data in Android auto on phone. Once your done plug in cord and do a fresh set up. You will be back up running Android auto. Now if it happens again you will need to repeat these steps. Good luck🤞 this works with all problem phones also including OnePlus phones especially I have a 9 pro.
  12. Arragorn
  13. Arragorn
  14. ASHISHDARA634
    Gingerbread Sep 30, 2021
  15. X1628591169686
    Cupcake Oct 6, 2021
    X1628591169686 , Oct 6, 2021 :
  16. X1628591169686
    Cupcake Oct 6, 2021
    Update
    Downloaded & updated the software for my Kenwood head unit and low and behold...
    No bloody difference at all
  17. Drew_Nollsch
    Cupcake Oct 7, 2021
    Drew_Nollsch , Oct 7, 2021 :
    Hi, I am having this same problem with Ford Sync software. Android Auto starts to boot then exits immediately.
    Build number:
    Oxygen OS 11.2.8.8.LE25BA
    Model LE2113
  18. suyashbiradar
    Cupcake Oct 7, 2021
  19. X1628591169686
    Cupcake Oct 9, 2021
    X1628591169686 , Oct 9, 2021 :
    So, if I understand some of the articles regarding Samsung's OS correctly, they have had to incorporate an Android Auto related fix to their latest update.
    Appears that Google have done something to Android Auto, washed their hands of the problem and are leaving the handset manufacturers to clean up the mess.
    I guess it's now up to OnePlus to show that they aren't going to let their customers feel less valued than Samsung's customers.
  20. ASHISHDARA634
    Gingerbread Oct 11, 2021
