2
Sound Android Auto Low Volume
  1. andyvee1969
    Cupcake Jul 6, 2018
    andyvee1969 , Jul 6, 2018 :
    Anyone else got the same problem?
    I use Android Auto with my car head unit (Skoda Kodiaq) to play music. I either use Google Play Music or MediaMonkey (preferred). The audio volume over bluetooth from either of these apps is fine. If I then connect the USB cable and start Android auto the volume of the same track at the same head unit volume is significantly lower than over BT, and is also significantly lower than the radio, playing mp3s from USB etc. I have turn the head unit up by about 25% to achieve the same volume level as BT audio.
    The same head unit with a cheap Motorola E does not have this volume discrepancy. With a HTC 10 there is a slight reduction with Android Auto, but nowhere near to the same extent as with the OP6. I have tried 3 different USB-C cables that work fine with the HTC 10, and 2 OP USB-C cables.
    As there is no way of adjusting the volume of Android Auto media volume on the phone does anyone else have this issue?
    SG1 and fgalvani70 like this.
  2. F_Tom_Verhoeven_Ftuy
    Cupcake Jan 12, 2019
    sulumae likes this.
  3. Tristan Hunfeld
    Cupcake Feb 28, 2019
    sulumae likes this.
  4. G_Iain_Janssens_ppNF
    Cupcake Apr 1, 2019
    sulumae likes this.
  5. Tristan Hunfeld
    Cupcake Apr 1, 2019
  6. Kenny_Vleminckx
    Froyo Oct 28, 2019
  7. Haimram
    Cupcake Mar 24, 2020
    Haimram , Mar 24, 2020 :
    Have someone found a solution for this issue? I have the same problem with my Seat arona sound unit and OP6T.
    Really frustrating cause i like using Android auto.
  8. DrJMun
    KitKat Mar 25, 2020
    DrJMun , Mar 25, 2020 :
    Does it happen with any music source? Is it happening after the latest update 10.3.2?
  9. Nomour
    Cupcake Aug 24, 2020
