Android auto not working
  1. shabab0477
    Donut Aug 14, 2019
    shabab0477 , Aug 14, 2019 :
    Previously I was using Android auto with OnePlus 6 with best performance but now I upgraded my mobile to OnePlus 7 it's not supporting Android auto . I cross checked it's working fine with OnePlus 6 but not with OnePlus 7 , so issue is with only OnePlus 7.please suggest
    MaximusOP7pro likes this.
  2. Nic2112
    Ice Cream Sandwich Aug 14, 2019
    Nic2112 , Aug 14, 2019 :
    Android Auto works perfectly fine on the OnePlus 7, I use it every day, but it doesn't work if you are on the Android Q developer preview.
  3. markroberts666
    Froyo Aug 14, 2019
  4. MaximusOP7pro
    Eclair Aug 17, 2019
    shabab0477 and wesleycolls like this.
  5. shabab0477
    Donut Aug 17, 2019
    shabab0477 , Aug 17, 2019 :
    I m on Android 9 only.
  6. MaximusOP7pro
    Eclair Aug 17, 2019
    shabab0477 likes this.
  7. shabab0477
    Donut Aug 27, 2019
    shabab0477 , Aug 27, 2019 :
    which cable ur using . I m using the dash charger cable red one
  8. Dirk66
    Gingerbread Aug 27, 2019
    Dirk66 , Aug 27, 2019 :
    Not always necessary, i use a cheap very short cable from Amazon and it works. But if you have problems it is prob. adviced to use the OP cable.
  9. barnabyj
    Honeycomb Aug 27, 2019
    barnabyj , Aug 27, 2019 :
    most people who had problems fixed it by trying a new cable. no problems with AA on my 7 pro. even using the new AA interface now. works even better than before.
  10. shabab0477
    Donut Aug 27, 2019
    any separate cable I have to purchase. other than what I received in box adaptor and cable .
  11. barnabyj
    shouldn't but some people have said that they had to use another. I use the one that came with my 6t
  12. MaximusOP7pro
    Eclair Sep 6, 2019
  13. aloaiza
    Donut Sep 21, 2019
    aloaiza , Sep 21, 2019 :
    For me since using Android 10 Beta running Android Auto just slows down phone performance...it becomes sluggish and the UI sometimes becomes useless...it also changes the theme of the phone...
  14. redNwhite
    Eclair Sep 23, 2019
    Goggeboy likes this.
  15. MaximusOP7pro
    Eclair Sep 26, 2019
  16. defleloup
    Cupcake Oct 24, 2019
    defleloup , Oct 24, 2019 :
    Same for me.
  17. glitchsys
    Cupcake Nov 11, 2019
    glitchsys , Nov 11, 2019 :
    I have a OnePlus 6T and AndroidAuto was working great until I upgraded to Oxygen OS 9.0.17; suddenly when I connect my phone to the car it'll try to launch AndroidAuto on my phone but then the program will immediately close. Sometimes I'll get some error message on the cars Head Unit. If I try to launch the Android Auto app manually it crashes shortly after launch. This was definitely introduced, for me anyways, with the 9.0.17 upgrade (I'm still on Android 9 though, I haven't gone to Android 10 yet).
    redNwhite I owe you a beer! The solution you found about deleting user 999 worked!
    I'm thinking that my old version I didn't have the Work Profile/Parallel Apps thingbut the 9.0.17 upgrade introduced it to my phone somehow. I did the adb stuff and did find user 999 existed "Parallel Apps" so I went ahead and removed that user "adb shell pm remove-user 999" and now my car and my phone get along once again!
  18. sonny.haze
    Gingerbread Dec 26, 2019
