9
Android Auto not working
  1. nbucciii
    Cupcake Jan 14, 2020
    nbucciii , Jan 14, 2020 :
    Hi,
    I am having issues with AA on this phone. When I plug it in, it charges, but does not launch Android Auto or recognize it. I did a bit of research and tried setting to MIDI in default USB configuration, no change. Anyone else have this issue?
  2. alblackson
    Donut Jan 16, 2020
    alblackson , Jan 16, 2020 :
    Yes! Same thing! Me too! I'm very upset about it  I have a OnePlus 6. It happened after the latest Android Update for me.
  3. O1567620226593
    Cupcake Jan 19, 2020
    O1567620226593 , Jan 19, 2020 :
    same thing here.. when I plug in the USB in the car it does not launch AA and also for some reason the phone keeps forgetting the car paired car Bluetooth and I have to keep connecting it everytime I get into the car
  4. Chec+41
    Cupcake Jan 23, 2020
    Chec+41 , via OnePlus 5 , Jan 23, 2020 :
    Hi everyone,
    I had also many issues with AA with my OP5. I looked every where on Google... The best thing I've found so far is to plug the phone with a short USB cable into the car. Even the original one doesn't work. It crashes a lot less than before but I haven't be able to get WhatsApp or Telegram's notifications. Just the first time I plugged it in...
    I hope it could help some people...
    Nitin@21 likes this.
  5. River_Rhino , via OnePlus Community App , Mar 2, 2020 :
    you need to go to about phone and click on build number till it turns on the developer option then go to settings go down to system and click on it once open go to developer options turn it on and scroll down to debugging and turn on USB debugging this will allow AA to work
    X1600136004704 and Nitin@21 like this.
  6. PraHari
    Cupcake Mar 9, 2020
    PraHari , Mar 9, 2020 :
    I am also facing same problem. It's very pathetic to make call using android auto screen and other functions as well.
    Unlocking the phone every time to change track is too difficult band dangerous while driving.
  7. M1583867806973
    Cupcake Mar 10, 2020
    M1583867806973 , Mar 10, 2020 :
    After last update nothing is changed. In my car, with OnePlus 6, AA starts in 1 minute but the touch screen in my car doesn't work. I need to push physical button to change between apps. Please find a solution.
  8. O1566476870335
    Cupcake Mar 15, 2020
  9. B1544814471565
    Cupcake Mar 21, 2020
    B1544814471565 , Mar 21, 2020 :
    I'm glad I found this as I brought my new car a week ago a Peugeot 308 and my 6t doesn't even connect to Android auto.
    Have connected 2 Samsung phones and both worked fine.
    Any solutions chaps ?
  10. River_Rhino , via OnePlus Community App , Mar 22, 2020 :
  11. B1544814471565
    Cupcake Mar 22, 2020
    B1544814471565 , Mar 22, 2020 :
    well tried the usb debug thing but still would not work.
    But brought a new usb c leed today £1.50 my 4th leed I've tried and it's working.
    Don't see what's app on the display but everything else working well.
  12. River_Rhino , via OnePlus Community App , Mar 22, 2020 :
    I have a few of those data cables that don't work in my truck with my 7t pro but work on Samsung it's possible that both the leed and the debugging let you connect
    B1544814471565 likes this.
  13. sundgaard
    Cupcake Jun 9, 2020
  14. #14
  15. H1591807521474
    Cupcake Jun 10, 2020
    H1591807521474 , Jun 10, 2020 :
    You can also go to the Play Store and download Android Auto for Phone Screens, which is only available on Android 10 devices. Once you install the app, you can continue to use Android Auto on your phone screen.
  16. atlgator
    Cupcake Aug 18, 2020
    atlgator , Aug 18, 2020 :
    Not helpful.
  17. Luviathan
    Cupcake Aug 25, 2020
    Luviathan , via OnePlus 8 Pro , Aug 25, 2020 :
    Just bought a Honda Civic and tried plugging in my 8pro. All I can do is charge the phone. I used a note 20 ultra and it worked fine. I just bought a new charging cable and it didn't work. Can anybody confirm the developer mode and debugging "solution" actually works?
  18. Z1598369917688
    Z1598369917688 , Aug 25, 2020 :
    Not sure if that is the same problem for everybody. I tried all the things like everybody did - switching cables, switching phones and getting to the developer mode changing settings....and end up right before I go to the dealership, I reset the car system back to factory setup and after some waiting...for the system loading...it works just like when I got my car on the first day. Hopefully this helps.
  19. Zaelnorth
    Donut Aug 29, 2020
    Zaelnorth , Aug 29, 2020 :
    Amazing, just checked here and it seemed like OnePlus still haven't fixed this ages-old bug! I got rid of my oneplus because of this and I'm now happy Xiaomi user and android auto works every single time without having to screw around with developer options and other bs.
    Amazing they can make this work but "never settle" guys can't... Tells you something, good luck guys!
    lowi111 and Nitin@21 like this.
  20. L1581294334448 , via OnePlus 8 T-Mobile , Sep 5, 2020 :
    I found that changing the cable made the difference. I had a generic cable that worked with other phones, but it wouldn't work with my OP8. I took the charging cable that came with the phone and it worked perfectly
