7
[Submitted] Android auto slow usb connection after Android 10 update
  1. Bogeyd
    Gingerbread Jan 1, 2020
    Bogeyd , Jan 1, 2020 :
    When connecting phone to car head unit with USB, it takes couple minutes to car to connect to the phone and can't display Android auto in head unit before that.
    Phone shows usb is in charging mode. If changing usb mode to PTP, phone connects immediately.
    Tested with different cable also.
    Tested uninstall Android auto. Tested remove and reconnect car from Android auto settings.
    Car is Skoda Octavia 2017.
    It used to connect immediately in Android 9.
  2. DJ.Fernandes
    Cupcake Jan 8, 2020
    DJ.Fernandes , Jan 8, 2020 :
    I have exactly the same issue with exactly the same phone.
    I can immediate connect if I choose USB connection to PTP after I connect the phone to car, after that, android auto immediately starts up.
  3. X1581630758975
    Cupcake Feb 13, 2020
    X1581630758975 , Feb 13, 2020 :
    Experiencing this too. Other than manually changing the USB mode, has anyone found a solution?
    It's extremely annoying considering this is obviously because of the Android 10 update
  4. Bogeyd
    Gingerbread Feb 15, 2020
    Bogeyd , Feb 15, 2020 :
    One workaround;
    Go to options > default usb configuration > select PTP. Then it will connect fast, screen need to be unlock first.
    After changing, be sure you connect your device only to trusted usb devices, chargers and cables.
  5. Y1582123305121
    Cupcake Feb 19, 2020
    Y1582123305121 , Feb 19, 2020 :
    Hi, what do you mean by trusted USB devices? what risks are there by editing this option? Thanks
  6. TQxTim
    Cupcake Jul 29, 2020
    TQxTim , Jul 29, 2020 :
    No worries, my phone automatically switches back to "No Data" after Android Auto is being connected successfully.
    Hopefully OnePlus fixes this annoying Bug sometime in the future.
  7. C1609423312302
    Cupcake Mar 12, 2021
    C1609423312302 , Mar 12, 2021 :
  8. C1609423312302
    I have the exact same issue. Everything was fine until a recent update, now my Nord takes a couple of minutes before it connects. This is very poor - please sort this out.
    erikpienk likes this.
  9. V1576952430090
    Cupcake Apr 4, 2021
    V1576952430090 , Apr 4, 2021 :
    I have exactly the same problem. My phone used to connect immediately after plugged into the USB port, It takes a few minutes to connect for a while. As far as I experienced it's not related with the Android 10, because I have been using Android 10 with my Oneplus 7T Pro from the beginning and never faced this before. This only started happening recently. My Car is Skoda Superb!
  10. mtmaverick
    Eclair Apr 6, 2021
    mtmaverick , Apr 6, 2021 :
    Same problem here with VW Passat. Changing manually to PTP helps a bit, the phone connects faster, yet the connection is still not instant as it used to be on Android 10.
  11. L1597298593317
    Cupcake Apr 27, 2021
  12. F1617920369445
    Cupcake Apr 28, 2021
    F1617920369445 , Apr 28, 2021 :
    Same issue (with oneplus 9). Intolerably slow, uninstalling does not fix. Makes it virtually unusable because you have to wait several minutes before you can use the GPS to go anywhere.
  13. C1621450521871
    Cupcake May 19, 2021
    C1621450521871 , May 19, 2021 :
    Same issue. Oneplus 9 , VW golf 2019 car. Slow connction, takes about 4 minutes to see auto android.
  14. mamakawama
    Cupcake May 27, 2021
    mamakawama , May 27, 2021 :
    Just bought a '17 Passat and was astounded at how slow Android Auto connects with my phone (7T). Figured it was a VW issue.
    Never Settle, right?
    OnePlus software and support sucks.
  15. MarkySharky316
    Cupcake Jun 4, 2021
  16. jacker92
    Cupcake Jun 16, 2021
    jacker92 , via OnePlus 7 Pro , Jun 16, 2021 :
    I have the same problem with my car (VW Polo). It takes a couple of minutes until the connection is established ... That's really annoying!!!! Please fix that as soon as possible. The newest update didn't fix it.
  17. erikpienk
    Cupcake Jun 22, 2021
    erikpienk , Jun 22, 2021 :
    Same issue here with a OP7T and a VW Golf 2017. It takes like 2 minutes to connect. Latest Android Auto update didnt help at all.....please fix this issue!
  18. RuiAlves66
    Eclair Jul 7, 2021
    RuiAlves66 , Jul 7, 2021 :
    Same problem for me!
    OnePlus 8 Pro
    VW Tiguan (2018)
    Interesting that all claims here are related to VW group cars. Maybe there is a particular issue with VW radio software and/or firmware.
    R1619095052242 likes this.
  19. Ricky75700
    Cupcake Jul 14, 2021
    Ricky75700 , Jul 14, 2021 :
    Same issue here,
    OnePlus 7 Pro on Android 11 and now my OnePlus 9 on Android 11. While it worked as normal on Android 10.
    I've noticed while searching on Google that this issue only persists with Volkswagen-group cars (VW, Skoda, Seat, etc.)
    I'm currently mailing back and forth with the Android auto team to try to fix it. I also mailed my local VW dealer and asked them if they can update my head unit firmware.
    VW Polo 2019
    Partnr. head unit: 3Q0035874C
    Hardware: 853
    Software: 0891
    Maybe anyone else can share their info, I'll update here when I know more!
  20. pweelg
    Cupcake Aug 28, 2021
    pweelg , Aug 28, 2021 :
    Looks like I'm the only one without a vag group car. Honda civic 19 plate. Used to instant now anything between 30 seconds to 5 minutes.
