Android Auto wireless not internet connection
  1. Disttrack
    Eclair Apr 26, 2022
    Disttrack , Apr 26, 2022 :
    When I connect my oneplus 8t to android auto via wifi, I get a message in the apps indicating that I have no internet connection. I have tried to allow apps to connect in the background, I have activated the "Mobile data always active" option in the developer options, I have cleared app data and reconfigured but none of this works. Any suggestions? Thank you.
    Oxygen 12 with update C.16. In Oxygen 11 was working fine.
  2. Tokolozi
    The Lab Reviewer - OPPO Find N Apr 26, 2022
  3. Disttrack
    Eclair Apr 26, 2022
    Before reporting a bug I wanted to ask if there is any option that I am missing to make it work correctly. Thanks for the reply.
    Cz75 likes this.
  4. F1652189199573
    Cupcake May 10, 2022
    F1652189199573 , May 10, 2022 :
    @Disttrack did you manage to get anywhere with this?
    I have the same issue with my 8T since Android 12 update.
    If i toggle the wifi it usually reconnects to AA and also allows mobile data, but its hit and miss.
    this is the only real issue i have with the android 12 update but it is a big issue for me.
  5. Disttrack
    Eclair May 10, 2022
    Disttrack , via OnePlus 8T , May 10, 2022 :
    No, with wifi isnt usable, im using USB cable at the moment but It doesnt work properlt...
  6. N1652407656899
    Donut May 17, 2022
    N1652407656899 , May 17, 2022 :
    Oneplus 10 Pro on A12 works with data and wireless AA, so I know they are capable of making it work. BUT... now whenever I run Android Auto wireless, when I come home and turn off the car, the phone will refuse to auto connect to my known networks after. It's stuck on mobile data unless I manually go into wifi settings and click join network.
    If I leave the coverage area and return, it won't reconnect unless I manually join again. Same if I toggle wifi off/on. The only fix is a reboot, then it connects fine again. It's so strange how many issues Oneplus is having with this feature.
